Introduction
ThinkPad accepts PPC2700 chips up to 2 GB.
Ce dont vous avez besoin
Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
Carefully grab the battery, then pull it straight out, not at an angle.
Pry the cover open carefully (flathead screwdriver might help)
To remove the RAM memory stick, push both metal pieces holding it in place outwards, and the stick will pop up.
Pull the stick out carefully.
In order to replace the other stick, refer to the keyboard replacement tutorial. The other SODIMM is easily accessible with the keyboard removed.
7 autres ont terminé cette réparation.
