Introduction
Replacing or upgrading the RAM for the IBM T43 can give it a greater performance boost.
Pièces
Aucune pièce nécessaire.
To remove the cover, you will need to take out the single screw.
  • To remove the cover, you will need to take out the single screw.
  • Unscrew until the cover comes off
  • Lift the cover from the edge and pull off
  • If the cover doesn't come right up and you have felt that you have unscrewed it, you can lift the cover and the screw will come off with it.
Ajouter un commentaire
Place your hands on the clips and push on them outward until the RAM pops out
  • Place your hands on the clips and push on them outward until the RAM pops out
  • Place hands on the RAM and pull towards yourself
  • For replacement, follow these steps in reverse order
  • Make sure that when you put in the ram that the short side is on the right
aLiX pIeRRe
Membre depuis le 19/03/2018
699 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G4, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S6-G4, Bernier Spring 2018
UMASSD-BERNIER-S18S6G4
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 33
