Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Pièces
Aucune pièce spécifiée.
  1. Turn the computer over so that the back is facing upwards.
    • Turn the computer over so that the back is facing upwards.
    • Locate the screw in the bottom left-hand corner of the computer.
  2. Using a #0 Phillips screwdriver, remove the 17 mm screw.
    • Using a #0 Phillips screwdriver, remove the 17 mm screw.
  3. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  4. Carefully remove the plastic piece covering the hard drive by first pulling up then away  from the computer.
    • Carefully remove the plastic piece covering the hard drive by first pulling up then away from the computer.
  5. Locate the folded black tab within the hard drive port. With a screwdriver, pull the black tab out of the slot.
    • Locate the folded black tab within the hard drive port.
    • With a screwdriver, pull the black tab out of the slot.
  6. Pull gently on the black tab and the metal tray holding the hard drive will slide out. Pull gently on the black tab and the metal tray holding the hard drive will slide out.
    • Pull gently on the black tab and the metal tray holding the hard drive will slide out.
  7. Remove the plastic coverings on both sides of the hard drive.
    • Remove the plastic coverings on both sides of the hard drive.
    • Note that there is no hard drive in this picture but the process will remain the same.
5 autre(s) ont terminé cette réparation.
Kyle
Membre depuis le 18/04/2013
365 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 8-58, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 8-58, Johann Spring 2013
CPSU-JOHANN-S13S8G58
4 membres
10 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 3
7 derniers jours : 10
30 derniers jours : 31
Total : 4,302
