Aller au contenu principal
Pour réparer ensemble - Je crée un compte
IINE Retro Pocket Joystick Replacement
Ce dont vous avez besoin
  1. IINE Retro Pocket Joystick Replacement, Remove the screws: étape 1, image 1 de 3 IINE Retro Pocket Joystick Replacement, Remove the screws: étape 1, image 2 de 3 IINE Retro Pocket Joystick Replacement, Remove the screws: étape 1, image 3 de 3
    • Set the controller down on your working surface.
    • Flip the controller over so the back of the controller is facing up, with the shoulder buttons facing away from you.
    • Use a Phillips #1 screwdriver to remove the four black 7.5mm screws from the corners of the back plate.
    Demander à FixBot
    Ajouter un commentaire
  2. IINE Retro Pocket Joystick Replacement, Remove the back plate: étape 2, image 1 de 3 IINE Retro Pocket Joystick Replacement, Remove the back plate: étape 2, image 2 de 3 IINE Retro Pocket Joystick Replacement, Remove the back plate: étape 2, image 3 de 3
    • Use the tip of an opening pick to separate the back plate. Start at the bottom corner, and pry downwards.
    • As you make your way toward the center, you will eventually disengage the retaining clips located on either side of the status LED array.
    • Be careful not to damage the retaining clips. they're small and thin, and may break easily.
    • Lift the back plate up and away from you, and set it aside.
    Demander à FixBot
  3. IINE Retro Pocket Joystick Replacement: étape 3, image 1 de 1
    • Once the back plate is removed, you now have access to the internals of the controller.
    Demander à FixBot
  4. IINE Retro Pocket Joystick Replacement, Disconnect the battery: étape 4, image 1 de 3 IINE Retro Pocket Joystick Replacement, Disconnect the battery: étape 4, image 2 de 3 IINE Retro Pocket Joystick Replacement, Disconnect the battery: étape 4, image 3 de 3
    • For safety and to prevent damage, disconnect the battery before continuing.
    • Locate the battery connector.
    • Use a pair of tweezers to carefully push on the notches of the battery connector and disconnect it from the socket.
    • Do not pull on the wires!
    Demander à FixBot
  5. IINE Retro Pocket Joystick Replacement, Disconnect the right joystick: étape 5, image 1 de 3 IINE Retro Pocket Joystick Replacement, Disconnect the right joystick: étape 5, image 2 de 3 IINE Retro Pocket Joystick Replacement, Disconnect the right joystick: étape 5, image 3 de 3
    • Locate the ZIF connector of the right joystick.
    • Use a pair of tweezers to flip up the black flap of the ZIF connector and unlock it.
    • Disconnect the joystick cable by carefully pulling it straight out of the connector.
    Demander à FixBot
  6. IINE Retro Pocket Joystick Replacement, Unscrew the right joystick: étape 6, image 1 de 2 IINE Retro Pocket Joystick Replacement, Unscrew the right joystick: étape 6, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the two black 3.5mm screws that secure the right joystick.
    Demander à FixBot
  7. IINE Retro Pocket Joystick Replacement, Remove the right joystick: étape 7, image 1 de 2 IINE Retro Pocket Joystick Replacement, Remove the right joystick: étape 7, image 2 de 2
    • Lift up the joystick module and set it aside.
    Demander à FixBot
  8. IINE Retro Pocket Joystick Replacement, Disconnect the left joystick: étape 8, image 1 de 3 IINE Retro Pocket Joystick Replacement, Disconnect the left joystick: étape 8, image 2 de 3 IINE Retro Pocket Joystick Replacement, Disconnect the left joystick: étape 8, image 3 de 3
    • Locate the ZIF connector of the left joystick.
    Demander à FixBot
  9. IINE Retro Pocket Joystick Replacement, Unscrew the left joystick: étape 9, image 1 de 2 IINE Retro Pocket Joystick Replacement, Unscrew the left joystick: étape 9, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the two black 3.5mm screws that secure the left joystick.
    Demander à FixBot
  10. IINE Retro Pocket Joystick Replacement, Remove the left joystick: étape 10, image 1 de 2 IINE Retro Pocket Joystick Replacement, Remove the left joystick: étape 10, image 2 de 2
    Demander à FixBot
Once the controller is fully reassembled, connect it to your Nintendo Switch and calibrate the new joystick.
2 autres ont terminé cette réparation.
Aardimus
Membre depuis le 04/30/26
315 Réputation
2 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 85
Total : 259
