Aller au contenu principal
Ibanez 5 String Bass Model SR405QM Output Jack Replacement
Ce dont vous avez besoin
  1. Ibanez 5 String Bass Model SR405QM Output Jack Replacement, Battery: étape 1, image 1 de 1
    • Gently place the instrument upside-down on a soft surface.
    • Locate the battery cavity cap and screws.
  2. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 2, image 1 de 1
    • Use a Phillips #2 head screwdriver to unscrew both screws. Two #1 1mm long screws.
  3. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 3, image 1 de 2 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 3, image 2 de 2
    • Remove the cap by lifting upwards to reveal the battery.
  4. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 4, image 1 de 3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 4, image 2 de 3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 4, image 3 de 3
    • Gently lift the battery from the cavity.
    • Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
  5. Ibanez 5 String Bass Model SR405QM Output Jack Replacement, Backplate: étape 5, image 1 de 2 Ibanez 5 String Bass Model SR405QM Output Jack Replacement, Backplate: étape 5, image 2 de 2
    • Use a Phillips #2 screwdriver to remove the four screws on the backplate.
  6. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 6, image 1 de 2 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 6, image 2 de 2
    • Remove the cap by lifting upwards, revealing the circuitry of the instrument.
  7. Ibanez 5 String Bass Model SR405QM Output Jack Replacement, Output Jack: étape 7, image 1 de 3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement, Output Jack: étape 7, image 2 de 3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement, Output Jack: étape 7, image 3 de 3
    • Lift the green printed circuit board to move some of the wires.
    • Locate the output jack at the base of the cavity.
    • Move wires away from the end of the output jack to expose the three pins.
  8. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 8, image 1 de 2 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 8, image 2 de 2
    • Locate the gold nut at the base of the output Jack.
    • Do not remove the nut completely, but leave it about halfway down the output jack. We only want to move the prongs slightly away from all of the wires to allow for easier soldering.
    • Use the wrench to loosen the nut.
  9. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 9, image 1 de 3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 9, image 2 de 3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 9, image 3 de 3
    • Use a soldering iron to remove the three wires (two black, one white) from the output jack.
    • The soldering iron is extremely hot. Avoid contact with skin, fabric or the body of the instrument. When soldering iron is not in use, rest it on the soldering iron stand.
  10. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 10, image 1 de 3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 10, image 2 de 3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 10, image 3 de 3
    • Remove the loosened nut completely by rotating it counter-clockwise.
  11. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 11, image 1 de 3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 11, image 2 de 3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 11, image 3 de 3
    • Flip the bass over.
    • Remove output jack by pushing it gently from the back of the instrument and pulling it out from the front.
    • Insert a new output jack and tighten the nut about halfway.
  12. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: étape 12, image 1 de 1
    • Use the soldering iron to attach the wires on to the new output jack according to the wiring diagram.
    • Securely tighten the nut using the adjustable wrench.
To reassemble your device, follow steps 1-7 in reverse order.
4 autres ont terminé cette réparation.
Chris Pittner
Membre depuis le 01/11/13
220 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 5-18, Forte Winter 2013 Membre de l'équipe Cal Poly, Team 5-18, Forte Winter 2013
CPSU-FORTE-W13S5G18
4 membres
9 tutoriels rédigés
Un commentaire
Thanks for the good, clear instructions. Well done, very helpful.
m10, Socorro NM
Clifton - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 43
Total : 10,501
