Aller au contenu principal
IdeaPad Yoga 13 Charging Port Replacement
Ce dont vous avez besoin
  1. IdeaPad Yoga 13 Charging Port Replacement, Charging Port: étape 1, image 1 de 1
    • Remove all ten screws using the T4 Torx screwdriver.
    • Remove the back cover from the device.
  2. IdeaPad Yoga 13 Charging Port Replacement: étape 2, image 1 de 2 IdeaPad Yoga 13 Charging Port Replacement: étape 2, image 2 de 2
    • Use the blue opening tool to further separate the keyboard bezel.
    • Carefully apply pressure to the keyboard. It should easily pop out.
  3. IdeaPad Yoga 13 Charging Port Replacement: étape 3, image 1 de 1
    • To remove the keyboard bezel, unscrew and remove the five screws using the Phillips #0 screwdriver.
  4. IdeaPad Yoga 13 Charging Port Replacement: étape 4, image 1 de 2 IdeaPad Yoga 13 Charging Port Replacement: étape 4, image 2 de 2
    • Unplug the connections from the motherboard.
    • There is a different connection for the mouse and keyboard.
  5. IdeaPad Yoga 13 Charging Port Replacement: étape 5, image 1 de 1
    • Remove the outer bezel to reveal the entire internal layout of the computer.
    • Motherboard and other internal components are now exposed.
  6. IdeaPad Yoga 13 Charging Port Replacement: étape 6, image 1 de 3 IdeaPad Yoga 13 Charging Port Replacement: étape 6, image 2 de 3 IdeaPad Yoga 13 Charging Port Replacement: étape 6, image 3 de 3
    • Remove charging port by prying out the yellow port from the computer chassis.
    • Note the route of the cable for re-installation of the replacement.
2 autres ont terminé cette réparation.
Kaitlyn Johnson
Membre depuis le 04/01/19
157 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S1-G2, Harley Spring 2019 Membre de l'équipe IUPUI, Team S1-G2, Harley Spring 2019
IUPUI-HARLEY-S19S1G2
3 membres
2 tutoriels rédigés
Un commentaire
do you have the schematic of the board?
Jorge Herrera - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 19
Total : 1,633
