Aller au contenu principal
IdeaPad Yoga 13 RAM Module Replacement
Ce dont vous avez besoin
  1. IdeaPad Yoga 13 RAM Module Replacement, Keyboard: étape 1, image 1 de 1
    • Power off your laptop before beginning disassembly.
    • Open the laptop to locate the keyboard.
  2. IdeaPad Yoga 13 RAM Module Replacement: étape 2, image 1 de 2 IdeaPad Yoga 13 RAM Module Replacement: étape 2, image 2 de 2
    • Insert a plastic opening tool in the seam between the keyboard and laptop body.
    • Carefully run the tool around the top and sides of the keyboard to pop out the 9 tabs holding in the keyboard.
  3. IdeaPad Yoga 13 RAM Module Replacement: étape 3, image 1 de 3 IdeaPad Yoga 13 RAM Module Replacement: étape 3, image 2 de 3 IdeaPad Yoga 13 RAM Module Replacement: étape 3, image 3 de 3
    • Lift the keyboard up, then pivot it towards you to lay it facedown on the trackpad and palm rests.
    • Be careful when lifting the keyboard up. The ribbon cable connecting it to the motherboard is very short, and the connector is fragile.
    • The top corners of the keyboard may be stuck to the laptop bezel with double sided tape. See rectangles in Image 3. Be careful as you lift the keyboard up and pivot it toward you.
  4. IdeaPad Yoga 13 RAM Module Replacement: étape 4, image 1 de 3 IdeaPad Yoga 13 RAM Module Replacement: étape 4, image 2 de 3 IdeaPad Yoga 13 RAM Module Replacement: étape 4, image 3 de 3
    • Locate the ribbon cable connecting the keyboard to the motherboard.
    • Use the tip of the opening tool to lift the black flap on the connector.
    • With the twezers, gently lift the ribbon cable out of the connector.
    • Be careful when reinserting the ribbon cable.
    • Ensure the cutouts on the end of the cable match the tabs on the connector.
  5. IdeaPad Yoga 13 RAM Module Replacement, RAM Module: étape 5, image 1 de 2 IdeaPad Yoga 13 RAM Module Replacement, RAM Module: étape 5, image 2 de 2
    • Locate the RAM module.
    • Locate the retention clips holding the module in place, and gently push them outwards.
  6. IdeaPad Yoga 13 RAM Module Replacement: étape 6, image 1 de 1
    • The RAM module should pop up at an angle and can be lifted out.
    • When re-installing, insert the RAM module at the same angle, then push it down to re-engage the retention clips.
Remington Jones
Membre depuis le 01/17/17
756 Réputation
3 tutoriels rédigés
Équipe
Un commentaire
That helps a lot!
Ruiming Jia - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,465
