Introduction
Random Access Memory (RAM) stores programs and files for quick access while a computer is running. Damaged or defective RAM can lead to erratic behavior within programs and operating systems; insufficient capacity can make the laptop run slowly.
Ce dont vous avez besoin
Locate the ribbon cable connecting the keyboard to the motherboard.
Use the tip of the opening tool to lift the black flap on the connector.
With the twezers, gently lift the ribbon cable out of the connector.
Ensure the cutouts on the end of the cable match the tabs on the connector.
Locate the RAM module.
Locate the retention clips holding the module in place, and gently push them outwards.
