Aller au contenu principal
Impuls Blender Electronic wire Replacement
Ce dont vous avez besoin
  1. Impuls Blender Electronic wire Replacement, Electronic wire: étape 1, image 1 de 3 Impuls Blender Electronic wire Replacement, Electronic wire: étape 1, image 2 de 3 Impuls Blender Electronic wire Replacement, Electronic wire: étape 1, image 3 de 3
    • Here you see the Impuls blender
    • First, seperate the the blender jar from the bottom part by turning it and put it aside.
  2. Impuls Blender Electronic wire Replacement: étape 2, image 1 de 3 Impuls Blender Electronic wire Replacement: étape 2, image 2 de 3 Impuls Blender Electronic wire Replacement: étape 2, image 3 de 3
    • Turn the bottom part over and look at the bottom.
    • Take the rubber parts out of the 4 holes to reveal the screws.
    • Take the 4 screws out using a Phillips screwdriver.
  3. Impuls Blender Electronic wire Replacement: étape 3, image 1 de 3 Impuls Blender Electronic wire Replacement: étape 3, image 2 de 3 Impuls Blender Electronic wire Replacement: étape 3, image 3 de 3
    • Take the blue bottom part off the rest of the product to reveal the inside.
    • Unscrew the black piece to be able to slide the blue part away from the rest.
  4. Impuls Blender Electronic wire Replacement: étape 4, image 1 de 3 Impuls Blender Electronic wire Replacement: étape 4, image 2 de 3 Impuls Blender Electronic wire Replacement: étape 4, image 3 de 3
    • When you look to the inside, you see that there are two components; the buttons and the motor.
    • Unscrew the part that contains the buttons and take it off.
  5. Impuls Blender Electronic wire Replacement: étape 5, image 1 de 3 Impuls Blender Electronic wire Replacement: étape 5, image 2 de 3 Impuls Blender Electronic wire Replacement: étape 5, image 3 de 3
    • Take out the 3 screws that are deep inside.
    • Take off the blue part on top that was fixed with those screws.
    • Pull the black disc out by using the screwdriver as lever from multiple sides.
    • This will take some force, so do not be afraid it will break.
  6. Impuls Blender Electronic wire Replacement: étape 6, image 1 de 3 Impuls Blender Electronic wire Replacement: étape 6, image 2 de 3 Impuls Blender Electronic wire Replacement: étape 6, image 3 de 3
    • When you have taken off the black piece and revealed the 4 screws, unscrew them all.
    • Take out the motor part and the rest of the electronics.
  7. Impuls Blender Electronic wire Replacement: étape 7, image 1 de 3 Impuls Blender Electronic wire Replacement: étape 7, image 2 de 3 Impuls Blender Electronic wire Replacement: étape 7, image 3 de 3
    • Find the fraction in the wire.
    • Cut off the broken part
    • Strip both sides of the wire that have to be attached again.
  8. Impuls Blender Electronic wire Replacement: étape 8, image 1 de 2 Impuls Blender Electronic wire Replacement: étape 8, image 2 de 2
    • If you will use a shrink sleeve to cover the electronic wire, it has to be put on the wire first. Otherwise if electrical tape is used, this can be done afterwards.
    • Solder the two wires with a soldering iron.
    • Shrink the sleeve with a heater or put the electrical tape around the soldered wire.
To reassemble your device, follow the instructions in reverse order.
Daan van der Sande
Membre depuis le 03/08/17
101 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 35
Total : 1,020
