Aller au contenu principal
In-Ear Headphone Control and Mic Block Disassembly
Ce dont vous avez besoin
  1. In-Ear Headphone Control and Mic Block Disassembly, The Control Unit: étape 1, image 1 de 1
    • Find the edge of the control unit and get a very fine flathead screw driver (or a plastic pry tool which would do less damage)
  2. In-Ear Headphone Control and Mic Block Disassembly, Opening The Unit: étape 2, image 1 de 1
    • Wedge the tool in the corner and start sliding it to the left.
    • As you do this slowely twist the screw driver back and forth to release the clips.
    • Try not to let the tool slip into the control unit as this may damage the circuit board inside.
  3. In-Ear Headphone Control and Mic Block Disassembly, Removing The Cover: étape 3, image 1 de 2 In-Ear Headphone Control and Mic Block Disassembly, Removing The Cover: étape 3, image 2 de 2
    • Repeat step 2 and the control unit should open as seen in the image.
    • Remove the plastic sleeves and you will be left with just the circuit board (see second image).
  4. In-Ear Headphone Control and Mic Block Disassembly, Identify Broken Wire: étape 4, image 1 de 1
    • It is quickly seen that one of the wires has broken away from the circuit board (see image)
  5. In-Ear Headphone Control and Mic Block Disassembly, Resolder the Broken Wire: étape 5, image 1 de 1
    • Once the wire is found a steady hand and a fine tipped soldering iron should be used to reattach the wire.
    • Ensure that you do not head to circuit board for too long as it may cause damage (be as quick as possible!)
    • After this, the circuit board and wires should be replaced as they were before. Press the plastic cover halves together and it should click back into place.
    • And they are fixed!
Your headphones should now be working!
3 autres ont terminé cette réparation.
Alexander
Membre depuis le 09/10/18
233 Réputation
1 tutoriel rédigé
Un commentaire
Thanks a lot this worked perfectly thank you very much
MD Ratul - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 91
30 derniers jours : 404
Total : 10,243
