Aller au contenu principal
Pour réparer ensemble - Je crée un compte
InFocus IN3104 Top Cover Replacement
Ce dont vous avez besoin
    1. InFocus IN3104 Top Cover Replacement, Top Cover: étape 1, image 1 de 3 InFocus IN3104 Top Cover Replacement, Top Cover: étape 1, image 2 de 3 InFocus IN3104 Top Cover Replacement, Top Cover: étape 1, image 3 de 3
      • Turn the projector so that the lens is facing you.
      • On the left side of the projector, there is a screw and a knob inside of the small grate.
      • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
      • Remove the service cover.
      Demander à FixBot
      Ajouter un commentaire
    2. InFocus IN3104 Top Cover Replacement: étape 2, image 1 de 3 InFocus IN3104 Top Cover Replacement: étape 2, image 2 de 3 InFocus IN3104 Top Cover Replacement: étape 2, image 3 de 3
      • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
      • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
      • Remove the top cover.
      • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
      Demander à FixBot
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 24
Total : 535
