Aller au contenu principal
InFocus X2 Lamp Replacement
Ce dont vous avez besoin
  1. InFocus X2 Lamp Replacement, Open the Lamp Door: étape 1, image 1 de 3 InFocus X2 Lamp Replacement, Open the Lamp Door: étape 1, image 2 de 3 InFocus X2 Lamp Replacement, Open the Lamp Door: étape 1, image 3 de 3
    • Be sure that the projector is turned off, unplugged, and has cooled for at least 30 seconds.
    • Insert the Jimmy into one of the two notches on the lamp door's top edge.
    • Then use light force on the Jimmy to pry the latch away from the door.
    • If necessary, insert the Jimmy into the second latch and separate it from the projector.
    • Remove the door away from the projector by hand.
  2. InFocus X2 Lamp Replacement, Disconnect the Lamp: étape 2, image 1 de 3 InFocus X2 Lamp Replacement, Disconnect the Lamp: étape 2, image 2 de 3 InFocus X2 Lamp Replacement, Disconnect the Lamp: étape 2, image 3 de 3
    • Gently disconnect the lamp from the projector by using your thumb and forefinger to pinch on the white tab on the plug.
    • Then pull the plug away from the projector.
  3. InFocus X2 Lamp Replacement, Unscrew the Lamp from the Projector: étape 3, image 1 de 3 InFocus X2 Lamp Replacement, Unscrew the Lamp from the Projector: étape 3, image 2 de 3 InFocus X2 Lamp Replacement, Unscrew the Lamp from the Projector: étape 3, image 3 de 3
    • Use a Phillips #4 screwdriver or driver with the Phillips #4 head to unscrew the two 0.6 mm diameter brass screws from the lamp's housing.
    • For the lower screw, ensure it remains in the hole in the lamp assembly and it does not fall into the projector. If it falls in the projector, use a magnetized screw bit or a small magnet to pick it up and remove it.
  4. InFocus X2 Lamp Replacement, Remove the Old Lamp: étape 4, image 1 de 1
    • Pull on the bottom plastic tab and remove the lamp by hand.
  5. InFocus X2 Lamp Replacement, Insert the New Lamp: étape 5, image 1 de 1
    • Insert the replacement lamp into the projector.
Caution: The old bulb contains mercury. Please recycle it in a safe and appropriate manner. Look for your local recycling information at https://earth911.com/
Pièces jointes
Paulina Duarte
Membre depuis le 09/19/13
553 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 Membre de l'équipe UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G3
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 22
Total : 756
