Aller au contenu principal
India Mark II Head Section Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. India Mark II Head Section Replacement, Cover Plate: étape 1, image 1 de 1
    • Use a wrench to remove the bolt on the top of the cover plate.
    • When replacing the cover plate, this bolt only needs to be hand tight.
  2. India Mark II Head Section Replacement: étape 2, image 1 de 1
    • Remove the top cover by pulling it straight off the pump.
    • Store the top cover in a sanitary place, preferably above ground, to prevent contamination.
  3. India Mark II Head Section Replacement, Head Section: étape 3, image 1 de 3 India Mark II Head Section Replacement, Head Section: étape 3, image 2 de 3 India Mark II Head Section Replacement, Head Section: étape 3, image 3 de 3
    • Pull the pump handle all the way down and hold it in this position, exposing the pump rod.
    • Place the spacer around the pump rod and under the chain attachment point.
    • Make sure the spacer is beveled side down, and flat side up.
    • Lift the pump lever until there is no tension in the chain and hold it in this position.
  4. India Mark II Head Section Replacement: étape 4, image 1 de 2 India Mark II Head Section Replacement: étape 4, image 2 de 2
    • Remove the bolt connecting the chain to the pump handle.
    • Remove the chain from the handle.
  5. India Mark II Head Section Replacement: étape 5, image 1 de 3 India Mark II Head Section Replacement: étape 5, image 2 de 3 India Mark II Head Section Replacement: étape 5, image 3 de 3
    • There are 4 bolts securing the head section to the water tank, located at the corners of head section base.
    • Continue supporting the pump handle so the pump head doesn't fall off when all the bolts are removed.
    • Remove the 4 bolts on the base of the water tank.
  6. India Mark II Head Section Replacement: étape 6, image 1 de 1
    • Lift the pump head off of the water tank and place in a sanitary place, preferably above ground, to prevent contamination.
Phillip Takahashi
Membre depuis le 08/22/11
86 686 Réputation
87 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 662
