Aller au contenu principal
India Mark III Chain Replacement
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. India Mark III Chain Replacement, Chain: étape 1, image 1 de 3 India Mark III Chain Replacement, Chain: étape 1, image 2 de 3 India Mark III Chain Replacement, Chain: étape 1, image 3 de 3
    • Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
  2. India Mark III Chain Replacement: étape 2, image 1 de 3 India Mark III Chain Replacement: étape 2, image 2 de 3 India Mark III Chain Replacement: étape 2, image 3 de 3
    • The following procedure requires two people. If you attempt to do this alone, you risk injuring yourself and damaging the pump.
    • Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached.
  3. India Mark III Chain Replacement: étape 3, image 1 de 3 India Mark III Chain Replacement: étape 3, image 2 de 3 India Mark III Chain Replacement: étape 3, image 3 de 3
    • Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle.
  4. India Mark III Chain Replacement: étape 4, image 1 de 3 India Mark III Chain Replacement: étape 4, image 2 de 3 India Mark III Chain Replacement: étape 4, image 3 de 3
    • Hold the wrench on the bolt stationary.
    • Loosen the nut.
  5. India Mark III Chain Replacement: étape 5, image 1 de 3 India Mark III Chain Replacement: étape 5, image 2 de 3 India Mark III Chain Replacement: étape 5, image 3 de 3
    • Remove the nut from the chain bolt.
  6. India Mark III Chain Replacement: étape 6, image 1 de 2 India Mark III Chain Replacement: étape 6, image 2 de 2
    • Remove the washer from the chain bolt.
  7. India Mark III Chain Replacement: étape 7, image 1 de 2 India Mark III Chain Replacement: étape 7, image 2 de 2
    • Remove the chain bolt.
  8. India Mark III Chain Replacement: étape 8, image 1 de 3 India Mark III Chain Replacement: étape 8, image 2 de 3 India Mark III Chain Replacement: étape 8, image 3 de 3
    • Pull the top of the chain straight off of the pump handle.
Andrew Optimus Goldheart
Membre depuis le 10/17/09
508 715 Réputation
407 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 455 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 56
