Introduction
Follow this guide to remove the head of the India Mark III. You can then replace it or clean it, as necessary.
Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
Remove the hex head bolt from the top of the access door on the pump head.
Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
Remove the two bolts from the handle side of the pump head.
Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
