Aller au contenu principal
Infant Optics DXR-8 Charging Port Replacement
Ce dont vous avez besoin
  1. Infant Optics DXR-8 Charging Port Replacement, Internal Monitor Components: étape 1, image 1 de 3 Infant Optics DXR-8 Charging Port Replacement, Internal Monitor Components: étape 1, image 2 de 3 Infant Optics DXR-8 Charging Port Replacement, Internal Monitor Components: étape 1, image 3 de 3
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Charging Port Replacement: étape 2, image 1 de 3 Infant Optics DXR-8 Charging Port Replacement: étape 2, image 2 de 3 Infant Optics DXR-8 Charging Port Replacement: étape 2, image 3 de 3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Charging Port Replacement: étape 3, image 1 de 3 Infant Optics DXR-8 Charging Port Replacement: étape 3, image 2 de 3 Infant Optics DXR-8 Charging Port Replacement: étape 3, image 3 de 3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Charging Port Replacement, Charging Port: étape 4, image 1 de 2 Infant Optics DXR-8 Charging Port Replacement, Charging Port: étape 4, image 2 de 2
    • Unscrew the four 3 mm screws holding the motherboard to the unit using a Phillips #00 screwdriver.
  5. Infant Optics DXR-8 Charging Port Replacement: étape 5, image 1 de 2 Infant Optics DXR-8 Charging Port Replacement: étape 5, image 2 de 2
  6. Infant Optics DXR-8 Charging Port Replacement: étape 6, image 1 de 1
    • Remove the old charging port and solder the new one in place.
  7. Infant Optics DXR-8 Charging Port Replacement: étape 7, image 1 de 1
    • Flip the unit over to ensure a correct fitment.
Donovan Zusalim
Membre depuis le 01/24/17
293 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 13-4, Banghart Winter 2017 Membre de l'équipe Cal Poly, Team 13-4, Banghart Winter 2017
CPSU-BANGHART-W17S13G4
4 membres
4 tutoriels rédigés
2 commentaires
I appreciate you posting this. What kind of new charging port did you use (USB type, size, etc) and does IFIXIT sell them?
John Lynch - Réponse
The part you are looking for is a female Micro USB B-Type solder socket. I no longer have the unit available to confirm, but I'll bet you could contact Infant Optics and confirm with them. Sorry I can't be of more help!
Donovan Zusalim -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 53
Total : 5,721
