Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
The disassembling of the monitor is so to be able to change the screen or replace other components of the monitor.
Pièces
Aucune pièce spécifiée.
  1. Start by gently inserting the plastic opening tool between the led and casing.
    • Start by gently inserting the plastic opening tool between the led and casing.
  2. Slowly pry the cover away from the bottom using the plastic opening tool.
    • Slowly pry the cover away from the bottom using the plastic opening tool.
  3. Kits pour Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Glide the tool around the entire cover to reveal the screws, which are 5.0 mm.
    • Glide the tool around the entire cover to reveal the screws, which are 5.0 mm.
  5. Remove the cover and set it aside.
    • Remove the cover and set it aside.
  6. Remove the four corner screws, 5.0 mm, using a J1 bit. Lift the top away from the bottom using the metal spudger. Be careful not to rip the antenna wire.
    • Remove the four corner screws, 5.0 mm, using a J1 bit.
    • Lift the top away from the bottom using the metal spudger. Be careful not to rip the antenna wire.
6 autre(s) ont terminé cette réparation.
Larsha Johnson
Membre depuis le 26/08/2015
478 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 6-4, Remmell Fall 2015 Membre de l'équipe USF Tampa, Team 6-4, Remmell Fall 2015
USFT-REMMELL-F15S6G4
4 membres
3 tutoriels rédigés
What is the part number for the LCD?
jstarion - Réponse
From the pictures LQ035NC111 seem to be the part number.
Michael C -
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 5,822
