Aller au contenu principal
Introduction
You'll probably never need to diagnose an instrument light problem with your car, but that doesn't mean you can't have fun performing this test. And knowing that the gauges and lights are working is reassuring.
If you want to show this to friends, be warned that HID headlights service life can be reduced by turning them on and off needlessly. The bulbs aren't cheap. I recommend pulling the fuses for them before doing this repeated.
This procedure is specific to HONDAs and ACURAs.
Outils
Aucun outil spécifié.
Pièces
  1. This procedure involves turning on and off the headlights repeatedly, which which can reduce the HID headlights' mean lifetime before failure.  As a precursor, consider removing the 15A left & right low headlight fuses from the under-hood fuse box, positions 1 and 6. (Refer to your Owners Manual for instructions, or an iFixit guide.)
    • This procedure involves turning on and off the headlights repeatedly, which which can reduce the HID headlights' mean lifetime before failure. As a precursor, consider removing the 15A left & right low headlight fuses from the under-hood fuse box, positions 1 and 6. (Refer to your Owners Manual for instructions, or an iFixit guide.)
    • Be sure to reinstall the low beam headlight fuses before driving the vehicle.
  2. Insert the ignition key into the ignition lock. Leave it in the 0 or I position. Push and hold the Sel/Reset  knob (on the instrument panel by the fuel gauge), or the Sel/reset button on the right hand of the steering wheel below the Multi-Information Display  Info button. Push and hold the Sel/Reset  knob (on the instrument panel by the fuel gauge), or the Sel/reset button on the right hand of the steering wheel below the Multi-Information Display  Info button.
    • Insert the ignition key into the ignition lock. Leave it in the 0 or I position.
    • Push and hold the Sel/Reset knob (on the instrument panel by the fuel gauge), or the Sel/reset button on the right hand of the steering wheel below the Multi-Information Display Info button.
  3. Turn the headlights ON.
    • Turn the headlights ON.
  4. Turn the ignition switch to ON (position II). Some of the instrument lights will come on. If you aren't wearing your seatbelt, the seatbelt warning chime will sound.
    • Turn the ignition switch to ON (position II).
    • Some of the instrument lights will come on. If you aren't wearing your seatbelt, the seatbelt warning chime will sound.
  5. Within five seconds, and still holding in the Sel/Reset button, turn the headlights OFF, then ON, then OFF again. Within five seconds, and still holding in the Sel/Reset button, turn the headlights OFF, then ON, then OFF again. Within five seconds, and still holding in the Sel/Reset button, turn the headlights OFF, then ON, then OFF again.
    • Within five seconds, and still holding in the Sel/Reset button, turn the headlights OFF, then ON, then OFF again.
  6. Within 5 seconds, release the Sel/reset button. Push and release the Sel/reset button button 3 times repeatedly. The instrument cluster begins its self-test.
    • Within 5 seconds, release the Sel/reset button.
    • Push and release the Sel/reset button button 3 times repeatedly.
    • The instrument cluster begins its self-test.
    • Each successive press of the Sel/reset button initiates a new cycling of all the gauges.
    • To end, turn the ignition switch to OFF, or vehicle speed exceeds 1.5 mph.
    • If you removed the 15A headlight fuses from the under-hood fuse box in step 1, reinstall them before driving.
Ligne d'arrivée
12 autres ont terminé cette réparation.
David Spalding
Membre depuis le 12/11/2015
6 074 Réputation
9 tutoriels rédigés
2 commentaires
Folks, don’t post here asking about A COMPLETELY DIFFERENT VEHICLE. This page is for the 2004-2008 Acura TSX (Honda CL9), no others. Keep searching.
David Spalding - Réponse
I left decklid open overnight and now my instrument panel is not working
Anthony - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 78
7 derniers jours : 622
30 derniers jours : 2,764
Total : 229,908
