Introduction
Circuit boards may require replacement after consistent use. This guide will show how to remove the circuit board.
Pièces
Aucune pièce nécessaire.
Use a Phillips head #2 screwdriver to remove the 6mm screw.
  • Use a Phillips head #2 screwdriver to remove the 6mm screw.
Ajouter un commentaire
Twist the light grey plastic until the holes align with the blockers.
  • Twist the light grey plastic until the holes align with the blockers.
  • Remove the light grey plastic cover.
  • Remove the power cord from the slot it is inserted in.
  • Use a Phillips head #2 screwdriver to remove the 22mm screw connected to the black wire.
  • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the red wire.
  • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the blue wire.
  • Pinch the small white component connected to the circuit board.
  • Once pinched, wiggle this component until it is disconnected.
  • Pinch the red component connected to the circuit board.
  • Wiggle the wide white component until it is removed from the circuit board.
  • Use a J1 head screwdriver to remove the 8mm screws from both sides of the circuit board.
  • Use a Phillips head #2 screwdriver to remove both 15mm screws from either side of the circuit board, indicated in the picture.
  • Position the pressure cooker so that the circuit board is farther from you then the black, red, and blue wire connections.
  • To the right of the board, use a Phillips head #2 screwdriver to remove the 6mm screw.
  • Use a Phillips head #2 screwdriver to remove the 6mm screw behind and to the right of the circuit board tray.
  • Remove and replace the circuit board.
Savannah Webb
Membre depuis le 18/01/2018
639 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S12-G3, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S12-G3, Banghart Winter 2018
CPSU-BANGHART-W18S12G3
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 74
