Aller au contenu principal
Insignia Flex 11.6 Speakers Replacement
Ce dont vous avez besoin
  1. Insignia Flex 11.6 Speakers Replacement, Power Removal: étape 1, image 1 de 3 Insignia Flex 11.6 Speakers Replacement, Power Removal: étape 1, image 2 de 3 Insignia Flex 11.6 Speakers Replacement, Power Removal: étape 1, image 3 de 3
    • Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury.
    • Place the device on a firm surface with the device screen facing down.
  2. Insignia Flex 11.6 Speakers Replacement: étape 2, image 1 de 2 Insignia Flex 11.6 Speakers Replacement: étape 2, image 2 de 2
    • Remove 2, 6.1 mm Phillips J000 screws from the back of the device.
    • If any screws are stripped, refer to the ifixit guide for how to remove a stripped screw. Comment enlever une vis cassée
  3. Insignia Flex 11.6 Speakers Replacement: étape 3, image 1 de 3 Insignia Flex 11.6 Speakers Replacement: étape 3, image 2 de 3 Insignia Flex 11.6 Speakers Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Using a plastic tool and the plastic card, gently pry off the back cover.
  4. Insignia Flex 11.6 Speakers Replacement: étape 4, image 1 de 3 Insignia Flex 11.6 Speakers Replacement: étape 4, image 2 de 3 Insignia Flex 11.6 Speakers Replacement: étape 4, image 3 de 3
    • Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
  5. Insignia Flex 11.6 Speakers Replacement, Speakers: étape 5, image 1 de 1
    • Remove 2 electrical connectors that connects to the speaker using flat tweezers.
  6. Insignia Flex 11.6 Speakers Replacement: étape 6, image 1 de 2 Insignia Flex 11.6 Speakers Replacement: étape 6, image 2 de 2
    • Remove 2 - 6 mm J000 Phillips screws from each of the speakers.
    • Speakers will pop out at this point.
Connor Sweeney
Membre depuis le 09/28/16
449 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 511
