Introduction
This guide will show the steps required to disassemble an Insignia Ice Maker and replace the fan inside. It should take approximately 5-10 minutes.
Outils
Pièces
Aucune pièce nécessaire.
Undo the 6 Screws found on the bottom edge holding the rear casing on.
  • Undo the 6 Screws found on the bottom edge holding the rear casing on.
Ajouter un commentaire
Pull the casing off.
  • Pull the casing off.
  • Locate the fan on the side of the Ice maker and undo the 4 screws holding it in place.
  • Remove the cover from the circuit board by pressing against the lever to the side. A pry tool may be needed.
  • Follow the fan's power cable and unplug.
  • You may have to cut a zip tie holding the cable in place.
Evan Taylor
Membre depuis le 18/01/2018
544 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S21-G3, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S21-G3, Banghart Winter 2018
CPSU-BANGHART-W18S21G3
2 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 45
