Introduction
When the remaining batteries lose power, or die, you will need to replace them with new ones for your device to work. This guide will show you how to easily keep your device working.
Flip the stereo so the CD opening is face down.
  • Flip the stereo so the CD opening is face down.
  • With two fingers, pinch the tabs and lift up to open the battery protection cover.
Ajouter un commentaire
Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
  • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
  • Repeat until all eight batteries are removed.
  • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
Daniel Hodges
Membre depuis le 14/10/2013
301 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 4-31, Amido Fall 2013 Membre de l'équipe Cal Poly, Team 4-31, Amido Fall 2013
CPSU-AMIDO-F13S4G31
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 214
