Aller au contenu principal
Insignia NS-B4111 Speaker Replacement
Ce dont vous avez besoin
  1. Insignia NS-B4111 Speaker Replacement, Battery: étape 1, image 1 de 2 Insignia NS-B4111 Speaker Replacement, Battery: étape 1, image 2 de 2
    • Unplug and remove the power cord. Turn the boombox upside down.
    • Grip the sides of the case and use your thumbs to pop open the battery cover.
  2. Insignia NS-B4111 Speaker Replacement: étape 2, image 1 de 2 Insignia NS-B4111 Speaker Replacement: étape 2, image 2 de 2
    • Pry out the batteries with your fingers.
  3. Insignia NS-B4111 Speaker Replacement, Casing: étape 3, image 1 de 1
    • Turn the boombox upside down again. With the Phillips PH1 or the Flathead #3 screwdriver, remove the three 14mm black screws.
    • Remove the four 18mm chrome screws with the Phillips PH1 screwdriver.
  4. Insignia NS-B4111 Speaker Replacement: étape 4, image 1 de 2 Insignia NS-B4111 Speaker Replacement: étape 4, image 2 de 2
    • Gently remove the bottom half of the casing from the top half of the casing.
    • The antenna base is connected to the motherboard by a red wire. This wire will prevent the two halves from separating completely.
  5. Insignia NS-B4111 Speaker Replacement, Antenna Base: étape 5, image 1 de 2 Insignia NS-B4111 Speaker Replacement, Antenna Base: étape 5, image 2 de 2
    • Remove the 10mm chrome screw from the antenna base with the Phillips PH1 screwdriver. Remove the antenna base from the casing.
    • This red wire will now be loose and you can move it out of the antenna base slot.
  6. Insignia NS-B4111 Speaker Replacement, Motherboard: étape 6, image 1 de 1
    • Unscrew the four 12.5mm screws with the Phillips PH1 Screwdriver.
    • Unscrew the one 10mm long screw with the Phillips PH1 Screwdriver.
  7. Insignia NS-B4111 Speaker Replacement: étape 7, image 1 de 1
    • Orient the device so that the back is facing you.
    • Unplug the six pin male/female header from its socket on the motherboard. The wires on the header are these colors: burgundy, red, orange, yellow, green, and blue.
    • Use a tweezer if you find it hard to pull the header out with your fingers.
    • Gently pull out the ribbon cable from its socket on the motherboard.
    • Pay attention to the orientation of the header and the ribbon cable. Replacing the wires the wrong way may short circuit the board.
  8. Insignia NS-B4111 Speaker Replacement: étape 8, image 1 de 1
    • Rotate the device so that the front is facing you.
    • Unplug the four pin header from its socket on the motherboard. The wires on the header are these colors: brown, red, orange, and yellow.
    • Use a tweezer if you find it hard to pull this header out with your fingers.
    • Gently pull out the ribbon cable from its socket.
    • Pay attention to the orientation of the header and the ribbon cable. Replacing the base the wrong way may short circuit the board.
  9. Insignia NS-B4111 Speaker Replacement: étape 9, image 1 de 1
    • Pull out the two pin header from its socket on the motherboard. The wires on this header are black and white.
    • Use a tweezer if you find it hard to pull this cable out with your fingers.
  10. Insignia NS-B4111 Speaker Replacement, Front Panel: étape 10, image 1 de 1
    • Remove the four 8.5mm chrome screws from the front panel with the Phillips PH1 screwdriver.
  11. Insignia NS-B4111 Speaker Replacement: étape 11, image 1 de 1
    • Remove the front panel from the top casing.
  12. Insignia NS-B4111 Speaker Replacement, Speaker: étape 12, image 1 de 1
    • The following instructions will show you how to replace the left speaker. Follow the same instructions to replace the right speaker.
    • Use the blue opening tool to scrape the red adhesive off of the 12mm chrome screw.
  13. Insignia NS-B4111 Speaker Replacement: étape 13, image 1 de 1
    • Remove the 12mm chrome screw from the speaker with the Phillips PH1 screwdriver.
  14. Insignia NS-B4111 Speaker Replacement: étape 14, image 1 de 1
    • Remove any glue on the edges of the speaker.
  15. Insignia NS-B4111 Speaker Replacement: étape 15, image 1 de 1
    • Pop out the speaker from the front panel.
  16. Insignia NS-B4111 Speaker Replacement: étape 16, image 1 de 2 Insignia NS-B4111 Speaker Replacement: étape 16, image 2 de 2
    • Unsolder the two wires at the given points. If you need help soldering, see this guide.
    • The speaker has two colored wires attached to the orange plate: one attached to the positive (+) end, and the other attached to the negative (-) end.
    • The left speaker (shown) has a yellow wire on the positive (+) end, and an orange wire on the negative (-) end.
    • The right speaker (not shown) has a brown wire on the positive (+) end, and a red wire on the negative (-) end.
Kristin Yoshioka
Membre depuis le 09/21/16
984 Réputation
9 tutoriels rédigés
Équipe
UC Davis, Team 1-5, Oliver Fall 2016 Membre de l'équipe UC Davis, Team 1-5, Oliver Fall 2016
UCD-OLIVER-F16S1G5
5 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 8
Total : 527
