Ce dont vous avez besoin
Turn the boombox around to see the back, and then flip it upside down.
Insert a 2.5mm flathead driver into the two holes next to the battery compartment.
Turn the driver counterclockwise several times to loosen and pull out the 17mm screw.
Start by unplugging the red and black cable connected to the motherboard
To remove the cassette unit, use a 2.5mm flathead on the 4 screws holding the unit together.
Presque terminé !
