Aller au contenu principal
Insignia NS-CLIP02 Digital Display Replacement
Ce dont vous avez besoin
  1. Insignia NS-CLIP02 Digital Display Replacement, Motherboard: étape 1, image 1 de 1
    • Set the clock radio on the work space so the bottom of the device is showing.
  2. Insignia NS-CLIP02 Digital Display Replacement: étape 2, image 1 de 2 Insignia NS-CLIP02 Digital Display Replacement: étape 2, image 2 de 2
    • Use a metal spudger to peel back the adhesive sticker on the bottom of the clock.
    • You should see a single screw beneath the sticker.
  3. Insignia NS-CLIP02 Digital Display Replacement: étape 3, image 1 de 2 Insignia NS-CLIP02 Digital Display Replacement: étape 3, image 2 de 2
    • Using a plastic opening tool, peel off the adhesive gel stoppers.
  4. Insignia NS-CLIP02 Digital Display Replacement: étape 4, image 1 de 1
    • Use a Phillips screwdriver to remove the six 11 mm screws on the bottom of the device.
  5. Insignia NS-CLIP02 Digital Display Replacement: étape 5, image 1 de 1
    • Remove the bottom cover from the device to reveal the motherboard.
  6. Insignia NS-CLIP02 Digital Display Replacement: étape 6, image 1 de 1
    • Use a Phillips screwdriver to remove the 9.5 mm screw located near the center of the motherboard.
  7. Insignia NS-CLIP02 Digital Display Replacement: étape 7, image 1 de 1
    • Lift the motherboard away from the device.
  8. Insignia NS-CLIP02 Digital Display Replacement: étape 8, image 1 de 3 Insignia NS-CLIP02 Digital Display Replacement: étape 8, image 2 de 3 Insignia NS-CLIP02 Digital Display Replacement: étape 8, image 3 de 3
    • Disconnect the four cables connecting the motherboard to the device.
  9. Insignia NS-CLIP02 Digital Display Replacement, Digital Display: étape 9, image 1 de 1
    • Using the Phillips screwdriver, remove the three screws that run along the center of the base.
  10. Insignia NS-CLIP02 Digital Display Replacement: étape 10, image 1 de 2 Insignia NS-CLIP02 Digital Display Replacement: étape 10, image 2 de 2
    • Carefully remove the base.
  11. Insignia NS-CLIP02 Digital Display Replacement: étape 11, image 1 de 2 Insignia NS-CLIP02 Digital Display Replacement: étape 11, image 2 de 2
    • Using the metal spudger, gently lift the face plate away from the display.
  12. Insignia NS-CLIP02 Digital Display Replacement: étape 12, image 1 de 1
    • Once the face plate is removed, use the Phillips screwdriver to remove the six screws shown here.
  13. Insignia NS-CLIP02 Digital Display Replacement: étape 13, image 1 de 2 Insignia NS-CLIP02 Digital Display Replacement: étape 13, image 2 de 2
    • Using the metal spudger, lift the speaker grilles from the display.
    • The speaker grilles will hinge on the side closest to the display.
  14. Insignia NS-CLIP02 Digital Display Replacement: étape 14, image 1 de 1
    • Using the Phillips screwdriver, remove the four screws shown here.
  15. Insignia NS-CLIP02 Digital Display Replacement: étape 15, image 1 de 2 Insignia NS-CLIP02 Digital Display Replacement: étape 15, image 2 de 2
    • The two pieces of the display should easily separate.
  16. Insignia NS-CLIP02 Digital Display Replacement: étape 16, image 1 de 1
    • Using the Phillips screwdriver, remove the three screws shown here.
  17. Insignia NS-CLIP02 Digital Display Replacement: étape 17, image 1 de 3 Insignia NS-CLIP02 Digital Display Replacement: étape 17, image 2 de 3 Insignia NS-CLIP02 Digital Display Replacement: étape 17, image 3 de 3
    • The digital display should now be easy to remove.
    • Replace with new part.
Aubrey
Membre depuis le 02/24/15
214 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 9-3, Leahy Winter 2015 Membre de l'équipe USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 12
Total : 475
