Aller au contenu principal
Insignia NS-CLLT01 Button Replacement
Ce dont vous avez besoin
  1. Insignia NS-CLLT01 Button Replacement, Insignia NS-CLLT01 Top Casing Removal: étape 1, image 1 de 2 Insignia NS-CLLT01 Button Replacement, Insignia NS-CLLT01 Top Casing Removal: étape 1, image 2 de 2
    • Lift the four adhesive covers on each of the corners on the bottom of the clock using a plastic opening tool or your fingernail.
  2. Insignia NS-CLLT01 Button Replacement: étape 2, image 1 de 3 Insignia NS-CLLT01 Button Replacement: étape 2, image 2 de 3 Insignia NS-CLLT01 Button Replacement: étape 2, image 3 de 3
    • On the bottom of the clock, use your fingernail to push the battery cover to the right.
    • Lift the battery cover up and to the right to reveal the batteries.
  3. Insignia NS-CLLT01 Button Replacement: étape 3, image 1 de 1
    • Remove the two AA batteries by pressing the end opposite of the spring towards that spring and lifting up.
    • Once the batteries are removed, close the cover.
  4. Insignia NS-CLLT01 Button Replacement: étape 4, image 1 de 1
    • Use a long Phillips #2 screwdriver to unscrew all six 10mm Phillips screws inside the bottom of the clock.
    • Turn over the device to allow the screws to fall out, being careful to catch them so that you do not lose any.
    • The screws may not come out of the bottom of the clock. As long as you have unscrewed them, the clock can still be opened.
  5. Insignia NS-CLLT01 Button Replacement: étape 5, image 1 de 3 Insignia NS-CLLT01 Button Replacement: étape 5, image 2 de 3 Insignia NS-CLLT01 Button Replacement: étape 5, image 3 de 3
    • Turn the clock back over.
    • Lift the top off of the clock by gripping the back of the iPhone dock and pulling straight up.
  6. Insignia NS-CLLT01 Button Replacement, Button: étape 6, image 1 de 1
    • Using the Phillips #2 screwdriver, unscrew the seven 6mm Phillips screws on the circuit board that is attached to the top of the case.
  7. Insignia NS-CLLT01 Button Replacement: étape 7, image 1 de 1
    • Lift the circuit board from the device.
  8. Insignia NS-CLLT01 Button Replacement: étape 8, image 1 de 2 Insignia NS-CLLT01 Button Replacement: étape 8, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Detach the circuit board from the rest of the clock by gripping the sides of the white ribbon cable connector on the left-hand side of the board and pulling it straight off. You may need to use tweezers to grip the connector.
  9. Insignia NS-CLLT01 Button Replacement: étape 9, image 1 de 3 Insignia NS-CLLT01 Button Replacement: étape 9, image 2 de 3 Insignia NS-CLLT01 Button Replacement: étape 9, image 3 de 3
    • Use this soldering guide to remove and replace any buttons that were not working.
    • The buttons will be labeled on the top of the circuit board, and you will be working with the corresponding connections on the back.
Preston Jackson
Membre depuis le 09/23/15
201 Réputation
2 tutoriels rédigés
Équipe
Baylor, Team 6-9, Williams Fall 2015 Membre de l'équipe Baylor, Team 6-9, Williams Fall 2015
BU-WILLIAMS-F15S6G9
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 297
