Introduction
If the buttons on the device are not responsive, you may need to replace them, and this guide will show you how to do that, but does involve some soldering.
Ce dont vous avez besoin
Lift the four adhesive covers on each of the corners on the bottom of the clock using a plastic opening tool or your fingernail.
Using the Phillips #2 screwdriver, unscrew the seven 6mm Phillips screws on the circuit board that is attached to the top of the case.
