Introduction
If the radio antenna on your clock is broken and needs to be replaced, this guide will show you how to replace the cord. This process will include soldering.
Ce dont vous avez besoin
Lift the four adhesive covers on each of the corners on the bottom of the clock using a plastic opening tool or your fingernail.
Grip the white ribbon cable connector that attaches the lightning cable to the middle of the central circuit board located in the bottom of the clock. Pinch and pull straight up to detach the cable.
Use the narrow end of a plastic spudger to pull back the clip in the center of the board.
At the same time, pry the circuit board up by wedging another spudger into the top left-hand corner of the board and working it along the back, pushing the edge of the board away from the back of the clock.
Once the ports on the back of the circuit board are displaced and resting against the back of the clock, use a pair of tweezers to lift the circuit board up off of the bottom of the clock, continuing to feed the radio antenna through the side of the clock as the board lifts up.
Turn the circuit board back over.
Use this soldering guide to remove and replace the radio antenna that is attached to the corner of the circuit board.
