Aller au contenu principal
Insignia NS-CLOPP2 Screen Replacement
Ce dont vous avez besoin
  1. Insignia NS-CLOPP2 Screen Replacement, Screen: étape 1, image 1 de 1
    • Turn the clock over and remove the 1cm screw with a Philips head screwdriver, which is located below the faceplate, on the bottom of the clock.
  2. Insignia NS-CLOPP2 Screen Replacement: étape 2, image 1 de 1
    • Begin to pry the front screen off gently with a Jimmy tool made by Ifixit.
  3. Insignia NS-CLOPP2 Screen Replacement: étape 3, image 1 de 1
    • Once you are able to create a space in between the device and the front screen, use your hands to continue to pry off the screen. Make sure that all the mini latches surrounding the perimeter have been unlatched, allowing the screen to come off easily.
  4. Insignia NS-CLOPP2 Screen Replacement: étape 4, image 1 de 1
    • Once you have undone the latches and pried off the first half of the screen, use your hand to pull off the rest of the screen.
    • To reassemble your device, follow these instructions in reverse order.
2 autres ont terminé cette réparation.
Dilini De Silva
Membre depuis le 03/11/15
757 Réputation
5 tutoriels rédigés
Équipe
Marist, Team 1-1, Laflen Spring 2015 Membre de l'équipe Marist, Team 1-1, Laflen Spring 2015
MARS-LAFLEN-S15S1G1
2 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 250
