Aller au contenu principal
Insignia NS-F12R6-SS Motor Housing Replacing
Ce dont vous avez besoin
  1. Insignia NS-F12R6-SS Motor Housing Replacing, Front Cage: étape 1, image 1 de 2 Insignia NS-F12R6-SS Motor Housing Replacing, Front Cage: étape 1, image 2 de 2
    • Unplug your fan.
    • Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
  2. Insignia NS-F12R6-SS Motor Housing Replacing: étape 2, image 1 de 1
    • Remove the ring that runs around the edge of the fan cage.
  3. Insignia NS-F12R6-SS Motor Housing Replacing: étape 3, image 1 de 1
    • Remove the front of the fan cage.
  4. Insignia NS-F12R6-SS Motor Housing Replacing, Fan Blade: étape 4, image 1 de 1
    • Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
  5. Insignia NS-F12R6-SS Motor Housing Replacing: étape 5, image 1 de 1
    • Take caution when removing the fan blades. They can be sharp!
    • Slide the fan blade off the end of the rotor.
  6. Insignia NS-F12R6-SS Motor Housing Replacing, Back Cage: étape 6, image 1 de 1
    • Unscrew the four 8 mm bolts that fasten the back of the fan cage back to the motor housing with a Phillips #3 screwdriver.
  7. Insignia NS-F12R6-SS Motor Housing Replacing: étape 7, image 1 de 1
    • Pull the back cage off.
  8. Insignia NS-F12R6-SS Motor Housing Replacing, Oscillation Button: étape 8, image 1 de 2 Insignia NS-F12R6-SS Motor Housing Replacing, Oscillation Button: étape 8, image 2 de 2
    • Unscrew the 10 mm screw in the center hole of the oscillation knob with a Phillips #3 screwdriver.
  9. Insignia NS-F12R6-SS Motor Housing Replacing: étape 9, image 1 de 1
    • Remove the oscillation knob.
  10. Insignia NS-F12R6-SS Motor Housing Replacing, Motor Housing: étape 10, image 1 de 1
    • Use your fingers to gently pull the power knob directly away from the motor housing.
  11. Insignia NS-F12R6-SS Motor Housing Replacing: étape 11, image 1 de 1
    • Unscrew the flat 17 mm nut fastened at the bottom of the power knob with a small crescent wrench.
  12. Insignia NS-F12R6-SS Motor Housing Replacing: étape 12, image 1 de 2 Insignia NS-F12R6-SS Motor Housing Replacing: étape 12, image 2 de 2
    • Remove the four 6 mm bolts and small washers that secure the front face of the motor housing with a Phillips #3 screwdriver and remove the washers.
  13. Insignia NS-F12R6-SS Motor Housing Replacing: étape 13, image 1 de 1
    • Pull the front face of the motor housing off toward the front of the rotor.
  14. Insignia NS-F12R6-SS Motor Housing Replacing: étape 14, image 1 de 2 Insignia NS-F12R6-SS Motor Housing Replacing: étape 14, image 2 de 2
    • Remove the 10 mm triangular-headed bolt with a Phillips #3 screwdriver.
  15. Insignia NS-F12R6-SS Motor Housing Replacing: étape 15, image 1 de 1
    • Slide the back end of the motor housing away from the front of the rotor.
  16. Insignia NS-F12R6-SS Motor Housing Replacing: étape 16, image 1 de 1
    • Remove the small piece of paper hanging on the power button.
3 autres ont terminé cette réparation.
Hank
Membre depuis le 09/17/18
1 091 Réputation
8 tutoriels rédigés
Équipe
CSU Fullerton, Team S2-G1, Bruce Fall 2018 Membre de l'équipe CSU Fullerton, Team S2-G1, Bruce Fall 2018
CSUF-BRUCE-F18S2G1
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 21
Total : 1,544
