Aller au contenu principal
Insignia NSD9PDVD15 Screen Replacement
Ce dont vous avez besoin
  1. Insignia NSD9PDVD15 Screen Replacement, Screen: étape 1, image 1 de 2 Insignia NSD9PDVD15 Screen Replacement, Screen: étape 1, image 2 de 2
    • Slide the “Open” tab on the top of the device.
    • This will allow you to open the device.
  2. Insignia NSD9PDVD15 Screen Replacement: étape 2, image 1 de 1
    • Remove the six Phillips #00 screws from the screen casing.
    • To access two of the screws, first remove 2 small, flat rubber circles from the corners of the screen casing. Use a spudger if necessary.
  3. Insignia NSD9PDVD15 Screen Replacement: étape 3, image 1 de 1
    • Remove the two screws from the hinge that holds together the screen casing and the disk panel.
    • Abruptly opening the device too wide will break the hinge. To fully access the hinge screws, firmly but gently open the device wider.
  4. Insignia NSD9PDVD15 Screen Replacement: étape 4, image 1 de 1
    • Insert the plastic opening tool into the rectangular holes and pry open in order to access the interior of the screen casing.
    • Remove the four screws and corresponding washers from the edges of the screen.
    • Use a plastic opening tool to prop open if necessary.
  5. Insignia NSD9PDVD15 Screen Replacement: étape 5, image 1 de 1
    • Remove the eight screws from the green motherboard.
  6. Insignia NSD9PDVD15 Screen Replacement: étape 6, image 1 de 1
    • Unplug the red wires from the motherboard by gently pulling them off.
    • Then remove the screen.
  7. Insignia NSD9PDVD15 Screen Replacement: étape 7, image 1 de 1
    • Set the new screen in place.
Jen Rodas
Membre depuis le 09/30/15
1 Réputation
1 tutoriel rédigé
Équipe
Ohio State, Team 2-5, Garvin Fall 2015 Membre de l'équipe Ohio State, Team 2-5, Garvin Fall 2015
OSU-GARVIN-F15S2G5
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 463
