Introduction
Does your case have a crack? Want to clean out some dust or dirt trapped underneath the screen? This guide will help you take the front cover off.
Pièces
Aucune pièce nécessaire.
Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
Ajouter un commentaire
Detach the back cover by carefully pulling up and out on the back plastic casing.
  • Detach the back cover by carefully pulling up and out on the back plastic casing.
  • Do not pull apart the red wire connecting the battery to the device.
  • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
  • Be careful to not tear the wires while opening the case.
  • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
  • Do not disconnect wires from plastic connector.
  • Remove the four corner plastic covers on the back of the device using the plastic opening tool.
  • Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
  • Carefully wedge the plastic opening tool into either long side of the device.
  • Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
  • Repeat these steps on the other side of the device.
  • Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
Wesley Ballar
Membre depuis le 18/04/2013
88 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 12-36, Amido Spring 2013 Membre de l'équipe Cal Poly, Team 12-36, Amido Spring 2013
CPSU-AMIDO-S13S12G36
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 197
