Ce tutoriel a des changements plus récents. Passer à la dernière version non vérifiée.
Introduction
The Dell Inspiron 13 7359 2-in-1 is an excellent computer with a 3-cell, 43Wh battery, giving you 3-5 hours of battery life. If you find that the battery life has decreased significantly (the computer only lasts an hour or two on a battery life alone), if the battery starts to charge to full too slowly, or if your device is alerting you of any critical battery failures, it's an easy fix that's well worth the value of the computer. You won't need more than the actual replacement battery and a few tools to disassemble the computer, so follow this guide and keep this great computer in tip-top shape.
Ce dont vous avez besoin
Turn the laptop upside down with the logo facing the surface of the table.
Unscrew two 8mm screws with a Phillips #0 screwdriver.
Unscrew one silver, wide-head, 8mm screw with a Phillips #0 screwdriver.
Disconnect the battery cable from the motherboard.
To reassemble your device, follow these instructions in reverse order using a new battery.
2 autres ont terminé cette réparation.
