Aller au contenu principal
Inspiron 7359 2-in-1 Fan Replacement
Ce dont vous avez besoin
  1. Inspiron 7359 2-in-1 Fan Replacement, Disassembling the Inspiron 7359 2-in-1: étape 1, image 1 de 1
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Fan Replacement: étape 2, image 1 de 2 Inspiron 7359 2-in-1 Fan Replacement: étape 2, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Fan Replacement: étape 3, image 1 de 1
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Fan Replacement: étape 4, image 1 de 1
    • All hardware components should be exposed.
  5. Attention : les étapes 5 à 6 sont issues d'un tutoriel marqué comme étant en cours.
    Inspiron 7359 2-in-1 Fan Replacement, Hard Disk Drive: étape 5, image 1 de 1
    • Unscrew three 3mm screws with a Phillips #0 screwdriver and remove them.
    • These screws hold the hdd and removing these screws will make it easier to remove it.
  6. Inspiron 7359 2-in-1 Fan Replacement: étape 6, image 1 de 2 Inspiron 7359 2-in-1 Fan Replacement: étape 6, image 2 de 2
    • Lift the hard drive from the left side. Be careful not pull on it.
    • Pull the SATA cable that's connect to the hard drive and then carefully place the cable on the side.
  7. Inspiron 7359 2-in-1 Fan Replacement, Fan: étape 7, image 1 de 2 Inspiron 7359 2-in-1 Fan Replacement, Fan: étape 7, image 2 de 2
    • Carefully pull the fan adapter labelled one.
  8. Inspiron 7359 2-in-1 Fan Replacement: étape 8, image 1 de 1
    • Pull the wire from the hook to make it easier to take the whole fan out.
  9. Inspiron 7359 2-in-1 Fan Replacement: étape 9, image 1 de 1
    • Remove one 5mm screw using the Phillips screw.
    • After the screw is extracted use your hands and carefully take the fan out.
Dominique
Membre depuis le 08/26/19
251 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team S1-G3, Saknee Fall 2019 Membre de l'équipe Gateway, Team S1-G3, Saknee Fall 2019
GCC-SAKNEE-F19S1G3
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 26
Total : 449
