Ce tutoriel a des changements plus récents. Passer à la dernière version non vérifiée.
Introduction
The Dell Inspiron 13 7359 2-in-1 is an excellent computer with a 500GB Hard Disk Drive. If you find that the HDD is making unusual noises, performing slowly, corrupting your data, or giving you S.M.A.R.T. errors (Self-Monitoring, Analysis, and Reporting Technology), it's a good idea to replace the HDD. The S.M.A.R.T errors in particular mean your HDD might be failing soon, and that you need to backup your data or replace the HDD entirely. You might also want to upgrade the actual capacity, so long as you know the replacement is compatible with the device. You won't need more than the actual replacement HDD and a few tools to disassemble the computer, so follow this guide and keep your data intact.
Ce dont vous avez besoin
Turn the laptop upside down with the logo facing the surface of the table.
Unscrew three 3mm screws with a Phillips #0 screwdriver and remove them.
These screws hold the hdd and removing these screws will make it easier to remove it.
