Aller au contenu principal
Inspiron 7359 2-in-1 WiFi Card Replacement
Ce dont vous avez besoin
  1. Inspiron 7359 2-in-1 WiFi Card Replacement, Bottom Case: étape 1, image 1 de 1
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 WiFi Card Replacement: étape 2, image 1 de 2 Inspiron 7359 2-in-1 WiFi Card Replacement: étape 2, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 WiFi Card Replacement: étape 3, image 1 de 1
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 WiFi Card Replacement: étape 4, image 1 de 1
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 WiFi Card Replacement, WiFi Card: étape 5, image 1 de 2 Inspiron 7359 2-in-1 WiFi Card Replacement, WiFi Card: étape 5, image 2 de 2
    • Use the spudger tool to remove the two antenna cables.
    • Remove the black screw.
    • Slightly pull up the end and remove the WiFi card. Be careful not to damage the internal adapter.
Annberlisa Ronald
Membre depuis le 08/26/19
109 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team S1-G3, Saknee Fall 2019 Membre de l'équipe Gateway, Team S1-G3, Saknee Fall 2019
GCC-SAKNEE-F19S1G3
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 42
Total : 216
