Ce dont vous avez besoin
Si nécessaire, décollez les bouts de ruban adhésif qui maintiennent les câbles du capteur thermique du lecteur optique/disque dur dans votre iMac.
Débranchez le capteur thermique du disque dur en tirant son connecteur vers le haut de l'iMac.
I didn't do this on my 2133; just pushed wires out of the way.
Appliquez sur le support du disque dur une pression vers le bord inférieur de l'iMac pour le libérer du boîtier arrière, puis faites pivoter le haut du disque dur vers vous.
At first it looked like it needed extra force, rather stand the computer in its stand press the bracket firmly it will come out.
Great set of instructions altogether!
I just braced the foot/stand against my thigh and found there wasn't much force needed. Had to do it twice as I missed the foam pad on the drive I was replacing.
The whole process was simpler than I expected.
I seem to have missed something somewhere as I now have a lot more fan activity than before. A missed sensor connection maybe. Not looking forward to tracking it down.
I worked with the top of the screen facing me. It was very easy to brace my fingers and press with my thumbs to release the drive. I recommend doing it that way if you can.
I just used pliers….. Easy!
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
4 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Fabienne Detoc nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Un commentaire
Walter, I was working on a mid-2007 IMac (2133) and found your instructions helpful but not always complete or right. I have added some comments in some of the steps to clarify.
Pull the temperature sensor cable for the optical drive well out of the way so you don't trap it when inserting the new hard drive.
kevinp - Réponse
