Aller au contenu principal
Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009
Ce dont vous avez besoin
  1. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009, Retirer les vis du boîtier inférieur: étape 1, image 1 de 1
    • Retirez les 10 vis suivantes par lesquelles est fixé le boîtier inférieur du MacBook Pro 13" Unibody :
    • Sept vis Phillips 3 mm.
    • Trois vis Phillips 13,5 mm.
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - Réponse
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - Réponse
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - Réponse
    I use a magnetic mat and place the screws in order on that :)
    Cary B - Réponse
  2. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009, Soulever le boîtier inférieur: étape 2, image 1 de 1
    • Soulevez légèrement le boîtier inférieur et poussez-le vers l'arrière de l'ordinateur afin de désengager les pattes de fixation.
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - Réponse
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - Réponse
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009, Batterie: étape 3, image 1 de 1
    • À titre de précaution, nous vous conseillons de débrancher le connecteur de la batterie de la carte mère afin d'éviter les décharges électriques.
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur de la batterie pour le débrancher de la prise sur la carte mère.
    Citation de gansodesoya :
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - Réponse
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - Réponse
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - Réponse
  4. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009, Remplacement du lecteur optique dans le MacBook Pro 13" Unibody mi-2009: étape 4, image 1 de 1
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur du câble du haut-parleur droit/caisson de basses pour le débrancher de la carte mère. Veillez à ne pas soulever la prise. Tirez le connecteur vers le lecteur optique.
    • Faites levier en passant sous les fils.
    Step 4 is correct as stated (pull up, not slide out). You'll definitely see this when you put it back in place, pushing down in socket not sliding in. Just be careful and use spudger (gently!) underneath wires as shown.
    jgcolt - Réponse
    What is the best way to solder this back onto the board? I did it once 5 years ago, but that was my first and only time soldering. I know there is a soldering guide, and I have read it. Could someone tell me please the best way to reconnect the right speaker/subwoofer cable to the board, referencing the soldering guide?
    Leslie L. Gordon - Réponse
  5. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 5, image 1 de 1
    • Il est nécessaire de déplacer le petit clip de fixation du câble en plastique transparent (encadré en rouge) collé sur la carte mère de sorte qu'il ne vous gêne pas pour débrancher le câble vidéo. Lorsque vous l'écartez du connecteur du câble vidéo, faites attention à ne casser aucun des composants sur la carte.
    • Tirez le connecteur du câble vidéo vers le lecteur optique pour le débrancher de la carte mère.
    • Cette prise est en métal et plie facilement. Veillez à aligner le connecteur par rapport à sa prise sur la carte mère avant d'accoupler les deux pièces.
    When you put the Mac back together after this entire procedure, it's virtually impossible to get the camera cable reconnected because there is a small piece of plastic glued to the board to keep it from coming unplugged. An Apple store tech explained the piece of plastic and said it won't break anything if I pry it off the board. I did and then the cable connected easily.
    karenz - Réponse
    The retainer for the camera cable may be black as well as clear. It is much easier to remove and reinstall the retainer if the DVD drive cable is removed first.
    MikeG - Réponse
  6. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 6, image 1 de 1
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur du lecteur optique pour le débrancher de la carte mère.
  7. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 7, image 1 de 1
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur du disque dur pour le débrancher de la carte mère.
  8. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 8, image 1 de 1
    • Retirez les deux vis Phillips par lesquelles le caisson de basses est fixé au boîtier supérieur.
    • La plus longue des deux vis se trouve sur la droite.
    For step 8, I found I had to use a Phillips #0 screwdriver to remove the two screws. I'm not sure if mine were just over-tightened, but I couldn't get the two screws off with a cheapo Radioshack #00 screwdriver or a nice Wiha one for the life of me without coming close to stripping them. Tried the #0 and they popped right out. Hope this helps.
    Aaron B - Réponse
  9. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 9, image 1 de 2 Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 9, image 2 de 2
    • Ne retirez pas complètement le caisson de basses, car il est toujours raccordé au haut-parleur droit.
    • Soulevez le caisson de basses du lecteur optique et posez-le au-dessus de l'ordinateur.
  10. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 10, image 1 de 2 Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 10, image 2 de 2
    • Retirez les deux vis Phillips par lesquelles le support du câble vidéo est fixé au boîtier supérieur.
    • La vis de droite peut rester captive dans le câble vidéo.
    • Soulevez le support du câble vidéo hors du boîtier supérieur.
    There's another type of bridge, black, with an extra piece of metal to hold the cable. You don't have to remove this bridge to unmount the optical drive.
    Martin - Réponse
  11. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 11, image 1 de 2 Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 11, image 2 de 2
    • Retirez les trois vis Phillips 2,5 mm par lesquelles le lecteur optique est fixé au boîtier supérieur.
    • Soulevez le lecteur optique par le côté droit et sortez-le de l'ordinateur.
  12. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009, Lecteur optique: étape 12, image 1 de 1
    • Débranchez le connecteur du câble du lecteur optique de celui-ci.
    • Ce connecteur est particulièrement long. Pour le débrancher du lecteur, veillez à tirer au centre du connecteur.
    • Si un CD ou tout autre objet est coincé dans votre lecteur, utilisez notre guide de réparation pour lecteur optique.
  13. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 13, image 1 de 1
    • Retirez les deux vis noires Phillips #0 qui sécurisent la petite attache métallique. Transférez cette attache sur votre nouveau lecteur optique ou SSD.
  14. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009, Second disque dur: étape 14, image 1 de 2 Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009, Second disque dur: étape 14, image 2 de 2
    • Libérez la cale en plastique du boîtier de disque dur pour baie optique en appuyant sur l'un des clips présents à chaque extrémité et sortez-la du boîtier.
    is it 9,5mm or 12,7mm for the caddy? My stuff macbook pro mid 2010, need advice what size is compatible. Thank you
    Adi Purba - Réponse
    All Macbooks use 9.5mm Optical Drive Caddy, also, If you’re wondering as well, the Optical Drive runs at SATA II speeds just like with the main hard drive area, so if you’re using a SSD, then it’s going to run at a slightly slower speed.
    - PS5iscool - - Réponse
  15. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 15, image 1 de 3 Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 15, image 2 de 3 Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 15, image 3 de 3
    • Assurez-vous que les connecteurs du disque dur sont orientés vers le bas avant de placer ce dernier dans le boîtier.
    • Insérez doucement le disque dur dans le boîtier à l'emplacement approprié.
    • Tout en tenant fermement le boîtier en place d'une main, appuyez sur le disque dur avec l'autre main pour le raccorder aux connecteurs du boîtier.
    Okay it seems like some models of MacBook Pro have issues with a fast (6Gbit/s) SSD in the optical bay. Even though my Mac says it offers 6Gbit on both bays it simply didn't work in the optical bay. So I switched places between the two drives and everything seems to work. My Mac booted from the old HDD in optical bay automatically and then I cloned it afterwards and changed the startup disk to the new one. As said before, don't put a fast SSD in the optical bay!
    Carl - Réponse
    This is an extremely late response to an old comment, but… whatev’s. My 2011 MacBook Pro had that issue: the main (HDD bay) SATA operated at 6Gbit, and while the optical bay said it was 6Gbit, the “Negotiated Link Speed” was like 1.5Gbits regardless of what you put in it (I can understand 1.5Gbits for an optical drive, but not for an SSD). Some of the early 2012 models did the same thing, from what I understand, but that was corrected pretty early on; both my 13” and 15” 2012’s run at 6Gb/s on both SATA busses.
    AJH -
    It’s not wise to swop the optidrive for an HD as there is no physical protection. The caddy is only intended for an SSD.
    Ben Ormerod - Réponse
  16. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 16, image 1 de 2 Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 16, image 2 de 2
    • Une fois le disque dur en place, réinsérez la cale en plastique tout en maintenant le disque dur contre le bas du boîtier.
    Normally with the HD enclosure there come a set of screws. use these to screw down the HD in the enclosure since you need to flip it up side down to reinstall it into the MBP
    Bart - Réponse
  17. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 17, image 1 de 2 Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 17, image 2 de 2
    • Fixez le disque dur au boîtier à l'aide de deux vis Phillips n°1.
    Where are these screws coming from? Were they part of the original optical drive?
    Bradley DeHerrera - Réponse
    The new enclosure should include these two Phillips screws.
    Sam Omiotek -
    Can someone show the step of removal process of hdd/SSD placed in the caddy? I am unable to revert this process. Do we have to apply back greater force to remove back the hard drive/SSD from the caddy?
    Tarun Kumar Verma - Réponse
    Gads, I wish they made a caddy where the optical drive was removable without having to remove the entire caddy. That is a major peeve of mine. Like… just mount it the other way! I don’t want to have to go through this entire process every time I upgrade the secondary drive.
    AJH - Réponse
    These screws seems to be located in different places on different enclosures. I had serious trouble getting the SSD that the previous owner of this MacBook installed out of the enclosure until I realized the screws holding the SSD in place were on the side and not on the bottom. In case anyone else has the same issue!
    nessie1001 - Réponse
  18. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 18, image 1 de 1
    • Fixez le support du lecteur optique au nouveau boîtier avec deux vis Phillips n°0.
    • Rebranchez les câbles que vous avez retirés du lecteur optique d'origine sur le boîtier de la baie optique.
    Replaced the optical with hdd, as well as replaced the hard drive with an ssd. Now I get the circle with a line through it. But, when I hold the option key down, it gives me both hard drives, PLUS, the thumb drive I have in the USB port with a Mountain Lion installer. It even shows the recovery disks, but gives me the circle with the line when I choose one. Any help is appreciated.
    claude - Réponse
    Mate,
    My mbp shipped with OS 10.8, and I had upgraded twice to 10.10
    I've a 10.7 USB which upgraded my old MBP.
    My plan today was to boot with my new ssd, my time machine back up and the Lion usb plugged in.
    I would then click on the Lion usb, and tell it to put the OS and time machine back up on the ssd.
    So I help down ALT and when it started it gave me the options of the usual Mac internal or the Lion USB.
    I clicked Lion, but instead of taking me to the install options (Disk utility, restore from time machine etc etc) it gave me that grey circle with a diagonal line through it. The no entry sign - grey on grey - that I think you have.
    Some googling said that it is because I was trying to usb a 10.7 install on a MBP that shipped 10.8
    You can't go back, apparently.
    So if any of the OSs are older than the mac you got, you will get this error. The grey in grey no entry.
    I just cloned my HDD to my ssd (Carbon copy cloner free 30 day trial) using an external stat-usb3 wire and all is good.
    Rory -
    I have a 17" Macbook Pro6,1 unibody with an Intel Core i5, 2.53GHz. I was successful installing a 250GB SSD in the DVD bay, and I'm able to boot from it. I did this by first installing OS X 10.9.4 on the SSD mounted into an external HD case, testing the system to see if it would boot up into the SSD, then installing the SSD and carrier in the DVD drive bay. The system now boots up from the SSD with no problems. If you are having installation problems, I recommend trying this method.
    roger hall - Réponse
    I just have finished installing second SSD to my MBP (unibody 15` 2010).
    First one was changed like one year ago. Samsung 500GB SSD. It is in my HDD bay and I'm running system from it.
    Today I put a new Samsung 1TB 850 Evo 1 SSD in to my optic bay.
    I encounter problem with SSD not recognized by Finder.
    But It was recognized by Disk Utility.
    What I did was I erase new SSD by Disk Utility. Then the new partition was created and now It has been seen by Finder.
    So If you see it in Disk Utility just erased it.
    Some extra info in under this link--> https://discussions.apple.com/docs/DOC-4...
    Wish you all luck :)
    rybafly - Réponse
    My installation went great thanks to the guide. I did notice a small thing that might make a good tip, and that is to inspect all the visible screws. I saw one that was slightly raised, and when I poked around with the spudger, I found 2 more that had worked themselves out a bit. Its probably something super rare but at the age of these things, it wouldn't hurt to check.
    Tineyi Chapisa - Réponse
  19. Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 19, image 1 de 3 Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 19, image 2 de 3 Installation d'un second disque dur dans le MacBook Pro 13" Unibody mi-2009: étape 19, image 3 de 3
    • Ne jetez pas ce lecteur ! Vous pouvez toujours l'utiliser à l'aide d'un câble de lecteur optique SATA à port USB.
    • Positionnez le connecteur du câble SATA devant le port du lecteur optique et branchez-le.
    • Branchez le connecteur USB sur votre ordinateur.
    There is a small metal button in the front of the drive and you can use that to eject the drive if you were wondering.
    Joseph Landry - Réponse
    Maybe that explain the eject button mechanism maybe….
    Die neue SSD wurde durch das Laufwerk ersetzt aber leider wird jetzt die alte HDD nicht mehr erkannt. Hatte schon ein anderer das Problem?
    Alexander Richter - Réponse
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
137 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Jake Devincenzi
Membre depuis le 04/18/11
117 260 Réputation
57 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 76
Total : 119,012
