Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Installing A Main Zipper In Your Patagonia Down Jacket
Ce dont vous avez besoin
    1. Installing A Main Zipper In Your Patagonia Down Jacket, Installing A Main Zipper In Your Patagonia Down Jacket: étape 1, image 1 de 3 Installing A Main Zipper In Your Patagonia Down Jacket, Installing A Main Zipper In Your Patagonia Down Jacket: étape 1, image 2 de 3 Installing A Main Zipper In Your Patagonia Down Jacket, Installing A Main Zipper In Your Patagonia Down Jacket: étape 1, image 3 de 3
      • Unzip the jacket and fold back the bottom corner.
      • Identify the start of the seam that is holding the zipper in place.
      Demander à FixBot
      Ajouter un commentaire
    2. Installing A Main Zipper In Your Patagonia Down Jacket: étape 2, image 1 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 2, image 2 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 2, image 3 de 3
      • Using a seam ripper, gently remove the stitches on the inside of the zipper.
      • Be careful not to accidentally puncture or tear the jacket.
      Demander à FixBot
    3. Installing A Main Zipper In Your Patagonia Down Jacket: étape 3, image 1 de 2 Installing A Main Zipper In Your Patagonia Down Jacket: étape 3, image 2 de 2
      • Bend the zipper teeth away from the zipper webbing to make it easier to reach the stitches that hold the zipper and webbing together.
      • Using the seam ripper, gently rip the seam between the zipper and zipper webbing.
      Demander à FixBot
    4. Installing A Main Zipper In Your Patagonia Down Jacket: étape 4, image 1 de 2 Installing A Main Zipper In Your Patagonia Down Jacket: étape 4, image 2 de 2
      • Continue ripping the seam holding the zipper to the webbing until you come to the top of the seam.
      Demander à FixBot
    5. Installing A Main Zipper In Your Patagonia Down Jacket: étape 5, image 1 de 2 Installing A Main Zipper In Your Patagonia Down Jacket: étape 5, image 2 de 2
      • When you come to the fold in the zipper webbing, insert the seam ripper between the two layers of webbing, and gently pull the stitches out.
      Demander à FixBot
    6. Installing A Main Zipper In Your Patagonia Down Jacket: étape 6, image 1 de 1
      • The zipper should now be free from the jacket and can be discarded.
      Demander à FixBot
    7. Installing A Main Zipper In Your Patagonia Down Jacket: étape 7, image 1 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 7, image 2 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 7, image 3 de 3
      • Identify where the zipper flap is still sewn into the jacket. Use the seam ripper to free the zipper flap from the jacket. The yellow rectangle in the photos above will help you identify the zipper flap.
      • Be careful not to damage the jacket with the seam ripper as you free the webbing.
      Demander à FixBot
    8. Installing A Main Zipper In Your Patagonia Down Jacket: étape 8, image 1 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 8, image 2 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 8, image 3 de 3
      • Lay the jacket flat and measure from the base of the zipper to the collar, along the seam you just removed. In our case we measured 27 inches.
      • The jacket should be flat, so you get an accurate measurement.
      Demander à FixBot
    9. Installing A Main Zipper In Your Patagonia Down Jacket: étape 9, image 1 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 9, image 2 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 9, image 3 de 3
      • Lay out your new zipper on a flat surface and use the measurement you recorded in the step above, starting from the zipper box, or the bottom of the zipper.
      • Mark the measurement with tailor's chalk.
      • Pull the zipper slider back behind the mark you just made.
      Demander à FixBot
    10. Installing A Main Zipper In Your Patagonia Down Jacket: étape 10, image 1 de 2 Installing A Main Zipper In Your Patagonia Down Jacket: étape 10, image 2 de 2
      • Measure one inch beyond where you just marked and make a second mark with tailor’s chalk.
      Demander à FixBot
    11. Installing A Main Zipper In Your Patagonia Down Jacket: étape 11, image 1 de 2 Installing A Main Zipper In Your Patagonia Down Jacket: étape 11, image 2 de 2
      • Cut the zipper between the teeth at the second mark you made.
      Demander à FixBot
    12. Installing A Main Zipper In Your Patagonia Down Jacket: étape 12, image 1 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 12, image 2 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 12, image 3 de 3
      • Use end nipper pliers to remove the teeth of the zipper between the two marks.
      • Use needle-nose pliers to remove all the leftover bits of the teeth from the zipper.
      Demander à FixBot
    13. Installing A Main Zipper In Your Patagonia Down Jacket: étape 13, image 1 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 13, image 2 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 13, image 3 de 3
      • Take a zipper stop and align it, posts down, just beyond the last remaining zipper tooth.
      • Crimp the zipper stop onto the zipper using pliers.
      Demander à FixBot
    14. Installing A Main Zipper In Your Patagonia Down Jacket: étape 14, image 1 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 14, image 2 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 14, image 3 de 3
      • Fold the excess zipper tape away from the teeth at a slight angle.
      • Sew the toothless end of the zipper down, backstitching to hold it in place.
      Demander à FixBot
    15. Installing A Main Zipper In Your Patagonia Down Jacket: étape 15, image 1 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 15, image 2 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 15, image 3 de 3
      • Align the toothless edge of the zipper with the inside serged edge of the zipper webbing.
      • The serged edge is the one with the zig-zag stitching.
      • Fold the top of the webbing down over the sewn zipper tape.
      • You can pin the zipper and webbing in place for more stability.
      Demander à FixBot
    16. Installing A Main Zipper In Your Patagonia Down Jacket: étape 16, image 1 de 2 Installing A Main Zipper In Your Patagonia Down Jacket: étape 16, image 2 de 2
      • Align the zipper and webbing in the sewing machine so that the zipper teeth are along the edge of the presser foot.
      • Sew a few stitches, removing pins before you come to them.
      Demander à FixBot
    17. Installing A Main Zipper In Your Patagonia Down Jacket: étape 17, image 1 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 17, image 2 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 17, image 3 de 3
      • Sew along the edge of the zipper teeth, making sure that the zipper and webbing stay aligned.
      Demander à FixBot
    18. Installing A Main Zipper In Your Patagonia Down Jacket: étape 18, image 1 de 2 Installing A Main Zipper In Your Patagonia Down Jacket: étape 18, image 2 de 2
      • Reinsert the zipper and webbing into the jacket, aligning the edge of the jacket fabric with the zipper teeth.
      Demander à FixBot
    19. Installing A Main Zipper In Your Patagonia Down Jacket: étape 19, image 1 de 2 Installing A Main Zipper In Your Patagonia Down Jacket: étape 19, image 2 de 2
      • While holding the zipper in place, move the fabric underneath the zipper out of the way so you’re only sewing the zipper to one layer of fabric.
      Demander à FixBot
    20. Installing A Main Zipper In Your Patagonia Down Jacket: étape 20, image 1 de 2 Installing A Main Zipper In Your Patagonia Down Jacket: étape 20, image 2 de 2
      • Install the zipper foot into your sewing machine.
      • Align the jacket and zipper in the sewing machine.
      • Be sure that there is no fabric behind the zipper webbing before you sew.
      Demander à FixBot
    21. Installing A Main Zipper In Your Patagonia Down Jacket: étape 21, image 1 de 2 Installing A Main Zipper In Your Patagonia Down Jacket: étape 21, image 2 de 2
      • Check your alignment and begin sewing, guiding the fabric along the zipper teeth.
      • Go slowly, re-aligning the fabric as you go.
      Demander à FixBot
    22. Installing A Main Zipper In Your Patagonia Down Jacket: étape 22, image 1 de 2 Installing A Main Zipper In Your Patagonia Down Jacket: étape 22, image 2 de 2
      • Continue sewing and re-aligning the zipper as you proceed along the full length of the zipper.
      Demander à FixBot
    23. Installing A Main Zipper In Your Patagonia Down Jacket: étape 23, image 1 de 1
      • When you reach the end of the zipper, backstitch to hold your stitches in place and remove the jacket from the sewing machine.
      Demander à FixBot
    24. Installing A Main Zipper In Your Patagonia Down Jacket: étape 24, image 1 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 24, image 2 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 24, image 3 de 3
      • Align the inside jacket fabric along the backside of the webbing.
      • Try to align the stitch holes directly over the stitches you just sewed.
      Demander à FixBot
    25. Installing A Main Zipper In Your Patagonia Down Jacket: étape 25, image 1 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 25, image 2 de 3 Installing A Main Zipper In Your Patagonia Down Jacket: étape 25, image 3 de 3
      • Align the jacket in the sewing machine, with the zipper webbing facing up.
      • Holding the inside fabric of the jack in place, sew directly over the original stitching.
      • Clip the threads, and admire your work!
      • Repeat this guide, ironing the webbing when you’re finished, to install the other side of the zipper.
      Demander à FixBot
Ligne d'arrivée
14 autres ont terminé cette réparation.
Brittany McCrigler
Membre depuis le 03/05/12
91 032 Réputation
142 tutoriels rédigés
7 commentaires de tutoriel
Very well documented.
Mike Macey - Réponse Partager
Have not yet completed my zipper repair very good tutorial. Thanks
mildred Norton - Réponse Partager
Well done, thank you so much. I was worried about the down falling out after I rip the old zipper, but I see that isn't a problem!
Js W - Réponse Partager
merci beaucoup pour ce tuto très explicite. Les photos montrent bien les points délicats et éclairent bien les 3 étapes importantes : coudre d'abord la fermeture sur la patte de fixation, puis le tissu extérieur sur la fermeture, enfin la doublure intérieure. Sans ces précisions, j'aurais pris directement la fermeture en sandwich et le résultat aurait été approximatif. Avec cette démarche, le résultat est parfait, même s'il y a 2 piqûres cote à cote.
Annie MAGALLON - Réponse Partager
詳しい説明ありがとうございます。お陰様でなんとかなおせました!
Ryoko H - Réponse Partager
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 36
30 derniers jours : 172
Total : 87,282
