1. Vehicle Preparation
Remove all loose items from the cargo area. Remove the cargo floor, spare wheel and tool tray.
Remove rear seats as in WIS instructions (Save seat mounting hardware)
Remove plastic covers
Remove Felt liner
Install and bolt down center support bracket (2 Bolts M10 x 1.5 x35mm 6mm Allen cap, 10mm flat washers)
Pay attention to the pin to align properly
NOTE: To service TPMS control module remove drawers ad service through access door in bottom plate.
2. Installation of Front Box
Place box inside vehicle. It fits through the rear doors. This is a 2 person job.
Mount front legs on front consoles, tighten loosely (2 Bolts M10 x 1.5 x35mm 6mm Allen cap, 10mm flat washers) . Pay attention not to break off the alignment pin, which will be inside the post after mounting.
DO NOT mount the box to the center bracket at this point
Set plate on brackets and align, overlapping the base plate of the front box on the center support bracket.
Use punch tool to align holes and drop in 2 bolts M8 x 1.25 x 40mm in holes on each side and one bolt M8 x 1.25 x 30 in the center hole.
Fully tighten M8 (20 Nm)
Fully tighten M6 (8 Nm)
4. Install box
Remove drawers and slide box on rail guides, align with bolt holes
Install 6 (M12) bolts and fully tighten to 66 Nm
Intégrer ce tutoriel
Choisissez une taille et copiez le code ci-dessous pour intégrer ce tutoriel sous la forme d'un petit widget sur votre site / forum.
Étape unique
Tutoriel complet
Petit - 600 px
Moyen - 800 px
Grand - 1200 px
Aperçu
