Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Integrated Headset Replacement
Ce dont vous avez besoin
  1. Integrated Headset Replacement, Integrated Headset: étape 1, image 1 de 3 Integrated Headset Replacement, Integrated Headset: étape 1, image 2 de 3 Integrated Headset Replacement, Integrated Headset: étape 1, image 3 de 3
    • Use a 6 mm Allen wrench to loosen the pinch bolts on each side of the stem.
    • Make sure to alternate between each side.
    Demander à FixBot
    Ajouter un commentaire
  2. Integrated Headset Replacement: étape 2, image 1 de 3 Integrated Headset Replacement: étape 2, image 2 de 3 Integrated Headset Replacement: étape 2, image 3 de 3
    • After loosening the bolts, the stem will be free to rotate.
    • Loosen and remove the top cap compression bolt.
    Demander à FixBot
  3. Integrated Headset Replacement: étape 3, image 1 de 3 Integrated Headset Replacement: étape 3, image 2 de 3 Integrated Headset Replacement: étape 3, image 3 de 3
    • Lift the bars and stem to remove them from the fork.
    • Turn the bars side to side while you pull up. This should help you remove a tight stem.
    Demander à FixBot
  4. Integrated Headset Replacement: étape 4, image 1 de 3 Integrated Headset Replacement: étape 4, image 2 de 3 Integrated Headset Replacement: étape 4, image 3 de 3
    • Remove the fork and headset from the bottom of the frame.
    Demander à FixBot
  5. Integrated Headset Replacement: étape 5, image 1 de 3 Integrated Headset Replacement: étape 5, image 2 de 3 Integrated Headset Replacement: étape 5, image 3 de 3
    • Remove the dust cap on top and replace the old bearings with the new headset if necessary.
    • Apply a thin coat of grease as needed on the frame’s head tube or steering head and fork.
    Demander à FixBot
  6. Integrated Headset Replacement: étape 6, image 1 de 3 Integrated Headset Replacement: étape 6, image 2 de 3 Integrated Headset Replacement: étape 6, image 3 de 3
    • Slide the fork back on the frame and place the compression ring on the upper headset bearing.
    Demander à FixBot
  7. Integrated Headset Replacement: étape 7, image 1 de 3 Integrated Headset Replacement: étape 7, image 2 de 3 Integrated Headset Replacement: étape 7, image 3 de 3
    • Slide the dust cover on and install the stem.
    • Check the amount of space between the top of the steerer tube and the top of your stem. Your steerer tube should lay just a few millimeters below, and allow for clamping and compression. If it doesn't, add a spacer on top of the dust cover and under the stem.
    Demander à FixBot
  8. Integrated Headset Replacement: étape 8, image 1 de 3 Integrated Headset Replacement: étape 8, image 2 de 3 Integrated Headset Replacement: étape 8, image 3 de 3
    • Reinstall the compression bolt and tighten it down, while at the same time keeping the bars in alignment.
    • Tighten the compression bolt until the thread becomes hard.
    • Use the socket wrench to turn the bolt half turn more and check for play by rocking the bars forward and backwards while pinching the frame with your knees.
    Demander à FixBot
  9. Integrated Headset Replacement: étape 9, image 1 de 3 Integrated Headset Replacement: étape 9, image 2 de 3 Integrated Headset Replacement: étape 9, image 3 de 3
    • Check for play and make sure the bars turn smoothly.
    • You don’t want to over tighten the compression bolt as this will result in improper steering.
    • Secure the pinching bolts on each side of the stem, alternating between each side as you go.
    Demander à FixBot
The final product should end up with aligned and firm bars. There should be no forward or backwards play and everything should turn smoothly.
Carlos
Membre depuis le 03/25/22
169 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 85
Total : 1,322
