Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This guide details the steps to take off the rear cover of your Inter-tel IP 8660.
Pièces
Aucune pièce spécifiée.
  1. Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out. 8 mm long 11 mm long
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Lift up the back cover and set it aside.
    • Lift up the back cover and set it aside.
Mariano Bautista
Membre depuis le 20/01/2012
16 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 11-24, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 membres
7 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 495
