Aller au contenu principal
Interlink VP4550 Case Replacement
Ce dont vous avez besoin
  1. Interlink VP4550 Case Replacement, Case: étape 1, image 1 de 3 Interlink VP4550 Case Replacement, Case: étape 1, image 2 de 3 Interlink VP4550 Case Replacement, Case: étape 1, image 3 de 3
    • Turn the phone over to where the battery compartment resides.
    • Remove the battery compartment door by pushing down on the door with your thumbs and sliding the door off of the bottom of the device.
    • Remove battery.
  2. Interlink VP4550 Case Replacement: étape 2, image 1 de 3 Interlink VP4550 Case Replacement: étape 2, image 2 de 3 Interlink VP4550 Case Replacement: étape 2, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the screw in the middle of the battery compartment.
    • Pry open the case body with the plastic opening tool. Start at the bottom of the device and work toward the top. You will hear a "click" sound as the sides open.
  3. Interlink VP4550 Case Replacement: étape 3, image 1 de 2 Interlink VP4550 Case Replacement: étape 3, image 2 de 2
    • There is a wire connector linking the front and the back of the device.
    • Carefully pull the wire connectors out of the white connector gauge to completely separate the front and back pieces.
  4. Interlink VP4550 Case Replacement: étape 4, image 1 de 2 Interlink VP4550 Case Replacement: étape 4, image 2 de 2
    • The power button may fall off when you separate the front and back of the device. This can simply be placed back when reassembling.
    • Find the lever on the right side of the back half of the device.
    • Insert the tip of the lever into the square indent on the underside of the button.
To reassemble your device, follow these instructions in reverse order. It's possible to either use a new case for your phone, or put the old one back on.
Rachel
Membre depuis le 02/12/14
1 Réputation
1 tutoriel rédigé
Équipe
Ohio State, Team 1-1, Buehl Spring 2014 Membre de l'équipe Ohio State, Team 1-1, Buehl Spring 2014
OSU-BUEHL-S14S1G1
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 306
