Aller au contenu principal
Outils
Pièces
Aucune pièce spécifiée.
  1. Push in the plastic tab that can be seen through cracks in the front left corner using a spudger. Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
    • Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
  2. Move down the same side and push in the plastic tab.
    • Move down the same side and push in the plastic tab.
  3. Move to the front right side and once again push in the plastic tab.
    • Move to the front right side and once again push in the plastic tab.
    • There is not a fourth tab to push in after this one.
  4. Grab the cover by the front side and pull upwards. You might encounter some resistance. Pull firmly, but don't yank it.
    • Grab the cover by the front side and pull upwards.
    • You might encounter some resistance. Pull firmly, but don't yank it.
  5. Tilt the front case down until the pegs detach from the bottom of the case. Lift up and outward.
    • Tilt the front case down until the pegs detach from the bottom of the case.
    • Lift up and outward.
    • The motherboard will be loose at this point.
4 autres ont terminé cette réparation.
Chris Rudolph
Membre depuis le 05/10/2010
73 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 7-53, Amido Fall 2010 Membre de l'équipe Cal Poly, Team 7-53, Amido Fall 2010
CPSU-AMIDO-F10S7G53
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 14
Total : 3,743
