Aller au contenu principal
Ion Air Pro Body Cover Replacement
Ce dont vous avez besoin
  1. Ion Air Pro Body Cover Replacement, Body Cover: étape 1, image 1 de 1
    • Unscrew all six screws.
    • Make sure you put the screws in a good spot where you won't lose them because they are small.
  2. Ion Air Pro Body Cover Replacement: étape 2, image 1 de 1
    • After you're done with unscrewing, take off the blue lid shown here.
  3. Ion Air Pro Body Cover Replacement: étape 3, image 1 de 1
    • On the other side of the device, lift this black piece of cover that is underneath the cap, on the bottom side of the Ion Air Pro.
  4. Ion Air Pro Body Cover Replacement: étape 4, image 1 de 1
    • After removing the black lid, unscrew all eight screws here.
    • Again, make sure you keep track of your screws and don't lose them.
  5. Ion Air Pro Body Cover Replacement: étape 5, image 1 de 1
    • Remove two more screws, one on each side, inside this socket.
  6. Ion Air Pro Body Cover Replacement: étape 6, image 1 de 1
    • Next, unscrew the two screws located here.
  7. Ion Air Pro Body Cover Replacement: étape 7, image 1 de 1
    • Detach the bottom black piece off from the bottom side but do not disconnect it from the wires.
    • Everything inside is still connected with all the wires, so be careful not to pull too hard or else everything inside could fall out or get broken.
  8. Ion Air Pro Body Cover Replacement: étape 8, image 1 de 1
    • Finally, you can remove the body cover off and replace it with a new one if you have to.
Christopher Brandl
Membre depuis le 10/09/18
673 Réputation
5 tutoriels rédigés
Équipe
UW Stout, Team S6-G2, Ogden Fall 2018 Membre de l'équipe UW Stout, Team S6-G2, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G2
4 membres
5 tutoriels rédigés
4 commentaires
Hey Chris where can I buy a replacement body cover?
The thread of the screw socket on my ion air pro WiFi has worn out and it can no longer be screwed onto any mounts.
Sam s - Réponse
I LOST THE LOSTTHE REAR COVER WHILE HUNTING. iS THERE A REPLACEMENT I CAN GET
mcbee1010 - Réponse
i lost the rear cover cap while hunting. can i purchase a new one
mcbee1010 - Réponse
Can you show a photo of the other side (compared to step 8) showing the mounting thread please?
Andrew Mawby - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 672
