Aller au contenu principal
Ion Air Pro Record and Stop Switch Replacement
Ce dont vous avez besoin
  1. Ion Air Pro Record and Stop Switch Replacement, Record and Stop Switch: étape 1, image 1 de 1
    • Remove the six screws (3 mm) that secure the lens cover bezel with a #00 Phillips screwdriver.
  2. Ion Air Pro Record and Stop Switch Replacement: étape 2, image 1 de 2 Ion Air Pro Record and Stop Switch Replacement: étape 2, image 2 de 2
    • Remove the blue securing the lens cover. Then simply pull off the lens cover itself.
  3. Ion Air Pro Record and Stop Switch Replacement: étape 3, image 1 de 1
    • Remove black aluminum casing as shown.
  4. Ion Air Pro Record and Stop Switch Replacement: étape 4, image 1 de 1
    • Using a #00 Phillips screwdriver, unscrew the screw securing the record/stop switch.
  5. Ion Air Pro Record and Stop Switch Replacement: étape 5, image 1 de 1
    • Remove the record/stop switch. You are then able to replace the switch.
    • Be careful to not misplace the power button and spring that will no longer be secured when the switch is removed.
Christopher Brandl
Membre depuis le 10/09/18
673 Réputation
5 tutoriels rédigés
Équipe
UW Stout, Team S6-G2, Ogden Fall 2018 Membre de l'équipe UW Stout, Team S6-G2, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 392
