Aller au contenu principal
Ivation IVWPDC20Y Lens Assembly Replacement
Ce dont vous avez besoin
  1. Ivation IVWPDC20Y Lens Assembly Replacement, Lens Assembly: étape 1, image 1 de 1
    • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
  2. Ivation IVWPDC20Y Lens Assembly Replacement: étape 2, image 1 de 1
    • Apply a plastic opening tool to each of the corners and gently remove the casing
    • The front casing is held down by adhesive and may require additional work to remove
    • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
  3. Ivation IVWPDC20Y Lens Assembly Replacement: étape 3, image 1 de 1
    • Remove the five silver screws from the inner casing using the PH00 screwdriver bit
  4. Ivation IVWPDC20Y Lens Assembly Replacement: étape 4, image 1 de 1
    • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit
    • These screws are very small and easy to strip so apply consistent pressure when removing them
  5. Ivation IVWPDC20Y Lens Assembly Replacement: étape 5, image 1 de 1
    • Pry off back outer casing using the black spudger or the blue prying tools
  6. Ivation IVWPDC20Y Lens Assembly Replacement: étape 6, image 1 de 1
    • Carefully remove the screen from the silver casing using a prying tool or the black spudger
    • There is adhesive in the center of the screen, be sure not to bend it when applying pressure
  7. Ivation IVWPDC20Y Lens Assembly Replacement: étape 7, image 1 de 1
    • Using the poker end of the spudger push gently on the black pegs holding the orange tape in place
    • Screen and orange tape should slip out as a whole
  8. Ivation IVWPDC20Y Lens Assembly Replacement: étape 8, image 1 de 1
    • Remove three screws holding the silver screen casing to the motherboard using the PH00 bit screwdriver
  9. Ivation IVWPDC20Y Lens Assembly Replacement: étape 9, image 1 de 1
    • Remove three screws holding the motherboard into the casing using the PH00 bit screwdriver
  10. Ivation IVWPDC20Y Lens Assembly Replacement: étape 10, image 1 de 1
    • Gently lift the corner of the motherboard out
    • Everything should come out as one component free of the casing
  11. Ivation IVWPDC20Y Lens Assembly Replacement: étape 11, image 1 de 1
    • Remove the two screws holding the lens assembly to the motherboard using the PH00 bit screwdriver
  12. Ivation IVWPDC20Y Lens Assembly Replacement: étape 12, image 1 de 1
    • Remove the soldering on the 3 wires that are connected to the lens unit
Jack Schlandt
Membre depuis le 02/08/16
197 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 6-6, Eyestone Spring 2016 Membre de l'équipe USF Tampa, Team 6-6, Eyestone Spring 2016
USFT-EYESTONE-S16S6G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 273
