Aller au contenu principal
JBL Charge 2 Battery Replacement
Ce dont vous avez besoin
  1. JBL Charge 2 Battery Replacement, Battery: étape 1, image 1 de 1
    • Remove the screen cover from the speaker using a metal spudger.
  2. JBL Charge 2 Battery Replacement: étape 2, image 1 de 2 JBL Charge 2 Battery Replacement: étape 2, image 2 de 2
    • Using a Phillips #1 screwdriver (PH1), remove the (4) four 8mm screws.
    • Remove the end cap of the device. Repeat the same process to remove the other end cap.
  3. JBL Charge 2 Battery Replacement: étape 3, image 1 de 2 JBL Charge 2 Battery Replacement: étape 3, image 2 de 2
    • To remove the end diaphragms, use a Phillips #1 screwdriver (PH1) and remove the (4) four 6mm screws.
    • Twist off the end cap and remove them from the device.
  4. JBL Charge 2 Battery Replacement: étape 4, image 1 de 2 JBL Charge 2 Battery Replacement: étape 4, image 2 de 2
    • Use a Phillips #1 screwdriver (PH1) to remove the (2) two screws from the battery cover.
    • Pry away the plastic battery cover with a plastic spudger.
  5. JBL Charge 2 Battery Replacement: étape 5, image 1 de 1
    • Disconnect the battery connector with a plastic opening tool and wiggle the connector free.
  6. JBL Charge 2 Battery Replacement: étape 6, image 1 de 3 JBL Charge 2 Battery Replacement: étape 6, image 2 de 3 JBL Charge 2 Battery Replacement: étape 6, image 3 de 3
    • Scrape the battery wire sealant off with a plastic opening tool, and ensure it is free of the body of the speaker and wires.
    • Slide the battery free.
10 autres ont terminé cette réparation.
Mauzor Ilonzo
Membre depuis le 09/26/17
495 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S2-G4, Passmore Fall 2017 Membre de l'équipe USF Tampa, Team S2-G4, Passmore Fall 2017
USFT-PASSMORE-F17S2G4
4 membres
8 tutoriels rédigés
3 commentaires
Thanks for the manual! Easy repair this way.
Jeroen Cox - Réponse
The JBL Charge 2 I have only needs the rear screen to be taken off. Once removed, just unscrew the battery holder plate. No need to unscrew the bass speakers. The battery plate is pretty well protected against water entering. You have to remove some silicone caulking to take out the power plug. My speaker takes the “New” Charge 2 battery.
Rogelio Fernandez - Réponse
Could you please suggest me where to buy battery for JBL Charge 2. Iam from Visakhapatnam, India. My mail vasudev.chiratla@gmail.com.
Vasudev Chiratla -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 69
30 derniers jours : 287
Total : 20,170
