Aller au contenu principal
JBL Charge 2 Plus Battery Replacement
Ce dont vous avez besoin
  1. JBL Charge 2 Plus Battery Replacement, Passive Radiators: étape 1, image 1 de 2 JBL Charge 2 Plus Battery Replacement, Passive Radiators: étape 1, image 2 de 2
    • Starting from the front side bottom left corner, use the nylon or metal spudger to lift the grille up from each of the four corners.
    • Follow the previous instruction to remove the back grille.
  2. JBL Charge 2 Plus Battery Replacement: étape 2, image 1 de 3 JBL Charge 2 Plus Battery Replacement: étape 2, image 2 de 3 JBL Charge 2 Plus Battery Replacement: étape 2, image 3 de 3
    • Unscrew the two .5 mm screws that hold the sub woofer in place.
    • Repeat the last step for the two screws on the back side.
  3. JBL Charge 2 Plus Battery Replacement: étape 3, image 1 de 2 JBL Charge 2 Plus Battery Replacement: étape 3, image 2 de 2
    • Remove the four screws that hold the passive radiator in place
  4. JBL Charge 2 Plus Battery Replacement: étape 4, image 1 de 1
    • Pop the Passive Radiator off.
  5. JBL Charge 2 Plus Battery Replacement: étape 5, image 1 de 3 JBL Charge 2 Plus Battery Replacement: étape 5, image 2 de 3 JBL Charge 2 Plus Battery Replacement: étape 5, image 3 de 3
    • Repeat Step 2, 3 and 4 for the other passive radiator.
  6. JBL Charge 2 Plus Battery Replacement, Battery: étape 6, image 1 de 2 JBL Charge 2 Plus Battery Replacement, Battery: étape 6, image 2 de 2
    • Remove the battery wire from the circuit board by pulling it out gently on the side closest to the LCD light.
  7. JBL Charge 2 Plus Battery Replacement: étape 7, image 1 de 1
    • Remove the 6 screws that hold the white cover in place.
  8. JBL Charge 2 Plus Battery Replacement: étape 8, image 1 de 2 JBL Charge 2 Plus Battery Replacement: étape 8, image 2 de 2
    • Use the plastic opening tool to remove the battery.
72 autres ont terminé cette réparation.
John Reynolds
Membre depuis le 10/16/15
3 134 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-1, Catania Fall 2015 Membre de l'équipe UMass Dartmouth, Team 4-1, Catania Fall 2015
UMASSD-CATANIA-F15S4G1
4 membres
12 tutoriels rédigés
37 commentaires
Great guide but where to source a battery for a JBL charge 2.
Mine failed, complained to Harman and they sent a new one and didn't want the old one so have a spare I'd like to get working.
Thanks in advance
Rob grist - Réponse
Had my speaker for a month. It won't charge. Why did it only last a month and I have to get a new one? I'm not satisfied with the speaker for the price that I paid.
Jeanette dagastine - Réponse
When I charge my jbl the light in tge power button turns on but when I press it the device does not respond. Please help me...
Tibetan Stoner - Réponse
Try disconnecting the battery and plugging it in again.
MarelyOscar -
I just had the same problem, the on/off led got stuck and couldn't get any sound or operation from any button. After different attempts a simultaneous pressing of the Phone together with the - and the + button brought my Charge2 to life again.
Javier G. Valdivia -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 77
30 derniers jours : 375
Total : 132,189
