Aller au contenu principal
JBL Charge 2 Plus Bottom USB Ports and Aux Port Replacement
Ce dont vous avez besoin
  1. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement, Bottom usb ports and  aux port: étape 1, image 1 de 1
    • Flip the device so the bottom is facing you.
    • Remove the bottom pad with a nylon or metal spudger.
  2. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: étape 2, image 1 de 2 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: étape 2, image 2 de 2
    • Remove the 4 screws that hold the white cover.
  3. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: étape 3, image 1 de 1
    • Slide under the cover and remove it.
  4. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: étape 4, image 1 de 2 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: étape 4, image 2 de 2
    • Remove the one screw holding the circuit board.
  5. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: étape 5, image 1 de 1
    • Pry the board with the plastic opening tool.
  6. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: étape 6, image 1 de 2 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: étape 6, image 2 de 2
    • Slide the ribbon gently out of the connector.
17 autres ont terminé cette réparation.
John Reynolds
Membre depuis le 10/16/15
3 134 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-1, Catania Fall 2015 Membre de l'équipe UMass Dartmouth, Team 4-1, Catania Fall 2015
UMASSD-CATANIA-F15S4G1
4 membres
12 tutoriels rédigés
15 commentaires
Hi! I need the mini usb piece but I don´t know were I can buy it, it is not like the mobile one´s! Please help me!
Thanks
Clash Ofclans - Réponse
Just having the same issue with the internally broken micro-usb connector. Is it standard, or something special? Thanks!
egyusza - Réponse
I think it is not normal, if you can find it please contact me! Thanks
I also need to replace my usb connector, has anyone found out where to get one?
Rick - Réponse
need the micro-usb aswell
hellgrenmicke - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 68
Total : 26,816
